Lol
I forgot you went to Brunters with it lol
Lol
http://img.photobucket.com/albums/v4...h_CIMG2418.jpg
Went for a spin in it to check the brakes and its seems they are all fine now, i will not disclose the problem but its all sorted lmao.
The gears have gone all homo just as i pulled on the drive and its got a oil leak that i am going to have sorted by my mate so i might as well just have him finish it all off.
Brakes had no pads fitted?lol
sounds awsome mate! once your mate has sorted the above, time to go back upto Mark's isnt it?
Sounds fooking superb. :cool:
That alone would make me glad i spent so much money/time in getting it where it is today :)
SO, what was wrong with the brakes? lol
I took it down to the garage earlier to have the ol leak fixed but on route i broke down:
http://img.photobucket.com/albums/v4...r/CIMG2421.jpg
Yep front wheel had come loose lmao
Anyhow at the garage the leak was diagnosed as been loose unions on the oil cooler plate, this was also linked tot he braking issue as well as the oil was spraying onto the barck of the drivers side disk!
http://img.photobucket.com/albums/v4...r/DSC00216.jpg
All tightened and fixed:
http://img.photobucket.com/albums/v4...r/DSC00217.jpg
Few other issues though, linkage feels like its binding causing problems with some gears, oil leak from the flywheel end of the sump and then there is this one:
http://img.photobucket.com/albums/v4...h_CIMG2420.jpg
F28 sounds like it wants to leave the building lmao.
I am getting my mate at the local garage to fix all of the above and i will supply a new F28 to fit.
Well thought deglazing the pads had fixed it, but it was actually all the oil on the rear of the drivers side disk causing the issue lol lolQuote:
Originally Posted by Adam
lol lol
lol what a beast!
From what I can see from the video clips you really only need 2 gears. 1 little normal one to get yourself going then 1 fooking great big straight cut gear out of some old tractor with the same ratio as 5th or 6thlol . Otherwise know as first and wheelspinlol lol
Sounds awesome rick :)
Glad to see it up and running again.... watching the vid the power just looks/sounds awesome :)
