Keep at it Benn. The more welding you do the better you'll get. A good mask helps too.
My mask is only a cheap one, but can see thru it ok when welding. Cheers dude.
Might be taking my engine out later...lol
Engine out???? Would make working in there easier I guess lol
Needs a bit of a rebuild. Was starting to smoke on hard boost and over run and such and worked out my oil leak is the oil pump gasket, not the sump as i thought before.
Best to get it all done now then I suppose. Might aswell fit a turbo upgrade while you're at it. I know where a GT28 & manifold are going cheap...... lol
It will be the **** kkk turbo smoking needs a hyrid kkk
looking good Benn.
David.
Si, turbo might go to James for a check over as i have no clue what its like on the inside, no play in the shaft tho. Wanna get the manifold bit coated to be cleaner. Ph2 will do me.
Stee, why wlll it?
David, thank you Sir.
Benn, your nova is a work of art mate.
Thank you :)
