Fair play to you benn, does the rad water pipe fit or does that need adjusting too, Was going for f28 in my saloon think you have just put me of lmao....
I'll look at that, the rear mount as two bits of threaded bar thru the holes where the bolts would go, which are screwed in to the holes in the box.. Would think that's ok...Quote:
Originally Posted by Rich
See above, with it like it is that should be ok no?Quote:
Originally Posted by damen
lol Is a bit of work. But they all tell me its worth it.Quote:
Originally Posted by sneakycorsa
it looks like the rear mount isn't bolted to the gearrbox in that picture. You want to make sure the rear mount is bolted up properly before u weld the mount on. Why is it on threaded bar at the minute?
I'd get it all bolted up properly ben. Good work thus far!
I'm using a empty dead casing, so the holes are the rear haven't been drilled and taped. But the holes are m8, so i have threaded bar thru the mount and in to the holes.. To make sure it lines up. In the pics it was before i moved it to line up with the rear mount.Quote:
Originally Posted by ben doodar
It should be right, there's still something in place..Quote:
good progress benn, :)
Cheers dude.
Did a final check up today, thanks to Dan for helping me.
Then James (CountVaux) came over with a very heavy duty welding for some action.
http://img.photobucket.com/albums/v3...ntwelding3.jpg
Looking nice.
Action shot..
http://img.photobucket.com/albums/v3...ntwelding2.jpg
You can see the penetration well, but has been welded on the inside too.
http://img.photobucket.com/albums/v3...ntwelding4.jpg
Nice beading, the holes been re-plated too.
http://img.photobucket.com/albums/v3...ntwelding5.jpg
Almost a shame to smooth over it all.. But needs to be done.
Well, I thought my welding was going alright considering the conditions, but after looking at that I think I give up lol
Fair play on James' behalf, that lads got skills
