Great work mate! Coming on well. :) can't wait to see it painted.
i also might have have to steal your wheel well plating idea :)
I just had a read through myself. Seeing it parked at the roadside early last year bought back fond memories.
Thanks, I can give you the measurements if you need them. The most important part, which I haven't actually mentioned is that there is a 90degree angle pressed into the plate where it meets the rear panel. Only 25mm, but it means it can be riveted to the panel. I cut the rest of the metal away underneath so it doesn't act as a parachute, then sealed it all up with PU adhesive. You can see the 4 rivets in this picture. I'l trim the bumper also.
http://i995.photobucket.com/albums/a...ps15a2874e.jpg
Yes its getting painted everywhere. Its on rolling dolly's, which I got off Craig (Twag), so despite being low, once its in the booth it will be jacked up on stands so its fully accessible
By all means do pop into the yard if you are passing, you can normally see my van from the road, so if its there..... I'm there.
If you could get me the sizes that would be great mate :)
Just had a look through my messages and found the measurements
730mm x 705mm with a 25mm 90deg return on one of the shorter sides making the flat part 730 x 680. Best use those as a rough guide though and measure yours properly when its cut out.
Cut the wheel well out at the area as soon as it goes flat with boot floor, To get the nice curved shape just hold a piece of string in one hand pressed to the wheel post, with the other hand holding the string and a marker pen. Then after a couple of dry runs you can mark it up with OCD levels of accuracy.
Thats 3mm, I wouldn't go thinner, place ally on top and draw round from underneath. Be careful not to cut on that line though, draw another around 20mm outside of it so it has a good overlap.
The paint stage! Exciting stuff can't wait to see it in one colour
Ta for the sizes :) book marked as i wont be getting there any time soon lol are you keeping the O.Z's on? i love them wheels
Thanks for that Craig, it will come in very handy :thumb:
So, what 2 weeks and this will be finished then yeah? ;)
