i try to update this thread as soon as i can... there's a lot to tell. But for now theres just a teaser...
http://i260.photobucket.com/albums/i...psbe47ad78.jpg
lol
lol
Getting air is awesome.
hardcore updates as always Mathias!!fantastic jump.
That thing looks evil!
Like this Benn lol
http://i345.photobucket.com/albums/p...SOUTHIEPNG.jpg
That would be impressive.
Hahaahahhaha nice photoshop lol
ok here's what happend the last few months:
After my suspension problems i started to search for a solution. Main thing i wanted to try is to maximize suspension travel.
Maximum suspension travel before (passenger side jacked up)
http://i260.photobucket.com/albums/i...pse067ac4f.jpg
intended suspension travel (driver side jacked up)
http://i260.photobucket.com/albums/i...ps01519ea4.jpg
while checking the suspension i noticed some play in the steering. steering arms worn out..
http://i260.photobucket.com/albums/i...ps9370b81e.jpg
so i decided to replace both steering arms. :)
http://i260.photobucket.com/albums/i...ps75e76417.jpg
To maximize suspension travel i ordered a new pair of tender springs which are 20mm longer than the ones that came with the coilover kit
http://i260.photobucket.com/albums/i...psf897dbfe.jpg
checked the lsd differential for possible problems and had the opportunity to make en oil change and replace seals.
http://i260.photobucket.com/albums/i...ps9b3f61a0.jpg
http://i260.photobucket.com/albums/i...psfecd3087.jpg
than ordered new springs for the rear to also modify suspension travel
http://i260.photobucket.com/albums/i...psf23712c3.jpg
found a lot of rust :wtf:
front driver side
http://i260.photobucket.com/albums/i...psfaf23cf7.jpg
rear driver side
http://i260.photobucket.com/albums/i...psd98a6bf8.jpg
and sorted out :thumb:
front
http://i260.photobucket.com/albums/i...ps38590a1c.jpg
and rear
http://i260.photobucket.com/albums/i...ps6f2d6230.jpg
found a way to reduce weight by changing the springs on the front
original coilover spring set: 1'159g
http://i260.photobucket.com/albums/i...ps352bae86.jpg
new spring set, longer tender srping, short main spring: 1015g! saved 144g per side :cool:
http://i260.photobucket.com/albums/i...psa81fda87.jpg
looks like this now
http://i260.photobucket.com/albums/i...ps30933deb.jpg
Rear suspension:
new tender springs, lot of travel and just 16mm when compressed.
http://i260.photobucket.com/albums/i...ps2c26551f.jpg
new rear spring setup
http://i260.photobucket.com/albums/i...ps0dd2393a.jpg
found a way to lower the car as much as possible and raise the roll center of the car by approx 30mm.
roll center (blue circle in the middle) before.
http://i260.photobucket.com/albums/i...psd68c7170.jpg
to raise the roll center the wishbone has to be moved 20mm upwards
http://i260.photobucket.com/albums/i...pse622515e.jpg
wishbone in original position
http://i260.photobucket.com/albums/i...psaa7ed108.jpg
drilled holes 20mm above the original ones
http://i260.photobucket.com/albums/i...psbe78e47f.jpg
wishbone mounted in new location
http://i260.photobucket.com/albums/i...ps95ef7fef.jpg
now the wishbone is pointing down, and the roll center is raised. this should minimize body roll.
http://i260.photobucket.com/albums/i...psb303e43d.jpg
Testing day :d
Had the cance to test my modifications at a trackday in france
http://i260.photobucket.com/albums/i...psa5c60ab7.jpg
the car felt much better than before, had to adjust the dampers and the suspensions problems are nearly gone.
http://i260.photobucket.com/albums/i...psf4a38c6b.jpg
cornering with less body roll
http://i260.photobucket.com/albums/i...ps1675e677.jpg
http://i260.photobucket.com/albums/i...psdeb26d3c.jpg
the tired marks on the right are mine... cold tires, too much speed... ran out of grey stuff lol luckely no damage to the car
http://i260.photobucket.com/albums/i...psf93390cc.jpg
unfortunately also ran out of brakepads :tard: after that the day was over :d
http://i260.photobucket.com/albums/i...ps44285107.jpg
