with a solid lifter you can be much more agressive with the ramp angles (meaning wider duration without needing to go for mental life), whereas a hydraulic lifter needs a fairly subtle ramp angle otherwise you can start to push the oil out etc
And a whole host of other issues like a hydraulic lifter jacking up with high revs (high oil pressure) leaving the valve open all the time
