Great work :)
Great work :)
Looks awesome dude, you now see why i hate doing head linings?
White/blue with the ring is oil pressure iirc.
white/ blue is battery charge lightQuote:
Cracking update there mate :thumb:
What cage is that btw??
Looks stunning mate, old Aberdeen reg IIRC too :)
Cheers for the comments.
Safety devices mate.Quote:
Amazing, Subscribed... :)
Coming along nicely Edd, liking the numberplates being in the older style lettering I guess they were done a while ago?
Cheers Southie, i got them of Rich, think he has had them made up a while ago. They are pressed metal ones, suit the car well imo.Quote:
Originally Posted by Southie
Edd, the oil sender is a later one which has a multiplug. The correct one has a stud & 6mm male blade. Great work BTW, nice to see it coming along.
Re the seatbelts, I was going to run four point harnesses. There is an extra hole drilled on each side of the rear seat pan for the eye to go through and fit to a strengthening plate.
I had them made at the Classic Car Show at the NEC a couple of years ago. They did them there & then.Quote:
It was supplied by SMT Aberdeen.Quote:
Looking fantastic mate :thumb: , not to sound or picky anything like that just noticed but that rear bumper is the wrong one i know coz i did the same lol it should be smooth at the bottom.
And will the rear decal fit ok now the spoiler is fitted?
As for the seat belt could you not take the plastic out put it on the bar first and some how thread it between the cage? it does look tight tho:eek:
I wouldnt cut it coz that means welding it in the car with the carpet fitted would be a nightmare if it cought fire.
I dont really want to fit harnesses so ii hoping there will be a way round it.Quote:
Originally Posted by Novasport
Seeing i have the wrong oil sender, (great payed 50 quid for it !!!) is that still going to work ?
in the pic below of the one i have, it has stud and a plug, and i have 3 wires any idea to which one goes to the stud ? and the plug ?
http://i499.photobucket.com/albums/r...S/SAM_0559.jpg
http://i499.photobucket.com/albums/r...S/SAM_0561.jpg
i think one is deffo the charge light that goes on the alternator, the one with the ring i think ? Do 2 wires go to the sender ?
Cheers, i know about the bumper, REALLY REALLY want the correct one but cant find a new or as new one anywhere :(.Quote:
Originally Posted by Mark Sparks
There is no chance of fitting the seat belt bar behind the cage, no chance lol think i have to look into it further.
The one in the midle goes to the altonater the other 2 go to the snder. Cant see why it wouldnt work mate just make sure by testing it with a oil preasure tester.
Blue with yellow tracer is the signal wire & brown is earth. Just checked early and late and its the same for both so your sender might be off something else like an XE. Either that or the earth stud is not used and the wires both go the the plug.
Do you have a part number for it? I can check on EPC then
**Edit** can you clean the mucky finger prints off the firewall please ;) lol
THIS is the sender iv got, Part Number: 90337695N
I don't have a brown wire tho.
I did notice the finger prints !! lol nightmare keeping it all clean tbh lol
26 switch, Oil Pressure (2 Connections)12s, 12st, 13s, 13sb, C14se, E16se
Chassis range -J4999999
Part number 90040918 12 52 5581
27 switch, Oil Pressure (2 Connections)12s, 12st, 12nv, E12gv, 13s, E16se, C16se
Chassis range K4000001-
Part number 90337695 12 52 563
26 is the correct one but EPC lists both as '2 connections' so should still work.
Sorry, both wire are blue/yellow. I have just been out to the garage and checked mine. Read wiring diagram which shows a wire going to earth and I wrongly presumed it to be a brown earth wire.
Nice one for looking, the ring on the stud and the other to the plug then I think ?
Top work Edd ;)
Nick.
Find a plug down the breakers & put it on the loom?
Nice update Ted, sorry we havent caught up whilst you were off.
The Nova is looking great mate, great project, really liking it :thumb:
What stuff did you use for the heated screen? Where did you get it from?
http://cgi.ebay.co.uk/OIL-PRESSURE-T...item35a4011fa7
This is what i'm using on the sport, not bad value at £13,
Great update, how much room is there between the seat belt mount and the cage? I cant see any other option than to use harneses if the mount wont fit between the cage and sill. Can you not fit the belt them put a load of force on the cage and push it into place?
looking good!
Any more updates Edd ? :)
Il sort some pics tomorrow, been doing a few bits :thumb: All takes time tho.Quote:
My Vectra died the other day so I'm having to put time/money into finding a new daily drive atm as well. :(
Ahhh right - Pain in the hole mate
Lucky its good weather, been down local srappy on my push bike for nova bits today lolQuote:
I'll sort some pics tomorrow but iv fitted the fuel tank, brake servo, few interior bits and a little more.
This turned up yesterday as well :d:d:d:d:d
http://i499.photobucket.com/albums/r...S/SAM_0572.jpg
http://i499.photobucket.com/albums/r...S/SAM_0573.jpg
THE BEST shocks for any nova, had them my old XE, awesome stuff.
Looks good fella :)
Only the best, need to get my finger out and fit mine
Not much use as your sing an SD cage, but theres absolutely no chance with an omp.
However, I put a rear SD cage in a gsi, and we kept the seat belts, we already had the bent metal mounts in, try unbolting cage, then putting them in, then putting cage back?
Having another look/think/shout/bend with the cage tomorrow, hopefully get something sorted with it.Quote:
Ok, pics of it if you dont mind fella!Quote:
Originally Posted by Edd
Its must go in somehow.
Were the legs pulled towards eachother with a strap when fitting?
I was always told to tention a cage when fitting etc?
MAybe because we pulled the legs in it fitted?
The only way of it fitting is if you bend the metal rail for the seat belt, i have a few in case it goes wrong lol
Just hope you dont crash and need that bar to be rightlolQuote:
Is it an mot failure? Altered seatbelt mountings?
I asked my mot mate and he said as long as the secure and not modified that they are weaker then its ok.Quote:
I dont think the bar will need that much bending, its just getting it right which is why im glad i have spare ones
Bit of a update, finished off a few things but not as much as i would of liked:(
Sorted out the new fuel tank, etch primed and sprayed silver, did the tank straps as well,
http://i499.photobucket.com/albums/r...Picture002.jpg
http://i499.photobucket.com/albums/r...Picture004.jpg
tank fitted
http://i499.photobucket.com/albums/r...Picture005.jpg
havnt done much with the interior, need to try fitting the cage again but wasnt in the mood for that today lol
Egine bay wise i have refurb the servo and m/c and refitted it, also refitted some of the gear linkage i had refurb along with new bushes and a quick shift, and fitted a brand new heater motor cover
http://i499.photobucket.com/albums/r...Picture003.jpg
http://i499.photobucket.com/albums/r...Picture006.jpg
managed to sort my oil pressure sender problem out yesterday, i just cut the plug off a corsa and now need to join it to the car loom and its sorted.
http://i499.photobucket.com/albums/r...Picture007.jpg
Been looking in to what wheels yo have, all the ones i like are either not made anymore or the wrong offset, although i really want some 14's as imo nova's drive best with them on i have decided to use the 15" steelies i got with the shell, they seem brand new. Need to sort some tyres for them and some BMW wheel bolts in black.
Managed to get a brand new set of old skool center caps that i will use;
http://i499.photobucket.com/albums/r...Picture008.jpg
More pics tomorrow with a proper camera :thumb:
Edd.
Nice progress Edd, what springs will you be running with the billies?
Also this is supposed to be on the engine mate not on the slam panel, it will never work. lol
Eibach springs mate,
lol pic was just to show the plug i got for the sender been hunting for the right one for a few weeks :thumb:
Cheers Edd I've been considering getting some new (standard style) shockers and springs for mine, how much of a drop is the Sport having, 40mm?
lol I just bought one of the ones linked a few pages back ;)
yep 40mm CBA's with all that ultra low buppyness lol
wish i knew about those senders before i paid 50 tho :(, yeah i bought one as a spare as well lol
You and your spares lol
Keep going matey tiz looking proper wikid mofo :d
