cav turbo speedo cable? i thought it was just all done by a transducer and wiring on the digi types?
What F28 do you have? The mechanical speedo drive one works with a cable drive, or the electronic one that has no speedo drive?
( the astra digi dash still requires the transducer to be driven by the speedo ring on the diff)
my f28 is the mechanical drive. so all im going to need i assumed was the transducer to run it, with no need to change speedo rings? also i want to change all the bulbs in it before it goes in. are these vauxhall dealer parts or can i get them from my local parts place? thanks
didgi bulbs are nls iirc, also if you have a mech f28 just fit a transducer and wire her up. :)
Can't you get digi dash bulbs on eBay ? Thought I'd seen them on there
im sure you can still get bulbs from vaux, i got some not so long ago.
and i liked my digi, craig it read fine for me... the fuel anyway.
and me and aw06 wired it in so it still has the normal 1.2 clock plug on there. so easily removed :)
i didnt have problems with it, but with an XE, it's just reacts slow.
it's really boring. needle going crazy is much more fun.
only good thing about a digidash is the shift ligt, as the rpm counter goes crazy if youre doing more than 7000 rpm (flashing)
Please sticky this post...............................
YES YOU CAN STILL BUY DIGI DASH HALOGEN BULBS FROM VAUXHALL FFS!!!lol
lol
and change the speedo drive or the speedo will be out, check the simps guide in articlesQuote:
Originally Posted by Rob
