It will be but I don't want it to be super long, but again not too close as I've suffered with high revs on the motorway in the NOva with it's F10 lol Just want it in the middle.
5th is different in all 3 F20'sQuote:
iirc someone on mig fitted the f18wr 5th into an f20. just do that.
Then i really don't get what you've put up there at all.Quote:
Originally Posted by Stuart
its a sample from a facking massive spreadsheet. this wont translate properly into text.
but the left most number after the gearbox name is 1st, then 2nd then 3rd then 4th then 5th then there is a column for 6th which is 0 in this case and then its the Final drives.
easy
But why is 5th and the final different? Surely they are the same gear?
I'm on my second F20 and this one is out of an SR 130, can't tell the difference
No.Quote:
if you took the FD out you would still be able to select 5th gear, but you wont go anywhere.
Perhaps a look at howstuffworks or wikipedia will help.
(think of it like a RWD car that has its gearbox upfront so 5th is in there it spins the prop shaft and turns the diff. the FD is in the diff)
Ah ok i get it a lil more.. Cheers.
