well i really want it to sit low if i can. the rears need pulling out so that should be doable, as for the fronts, im toying with slitting the arch upwards, pulling the wing away from the wheel slightly then fit another piece of wing behind it, if u follow me? also tempted to cut strut tops on inner wings and extend up, depending how much clerance the bonnet gives to sit the car lower
spec on nova is
c16xe, f28, lsd, rose joint tie bars, 5 stud, cav turbo discs, avo coilovers on front, 2.5" ss system, gsi dash, cav turbo clocks, rs turbo recaros retrimmed cloth, black bolsters, cream centres
