Phenomenol grip will pull the oil away from the pick-up.
Which in turn will result in blue engine parts.
The extra grip means everything on/in the car will get "thrown about" more and put under extra stress.
Ah i see, ok. Cheers guys. IaIn, best get on to Jonlem for a tie bar set up then....
Cheers, yeah hoover atachment is exactly what I had in mind! lol I will try and get some 2" steel tube and squash one end to narrow down the air to the right place.
Cheers for the info Craig, messaged him so will likely be using him if he's up for doing it
Dan runs 8-9'' wide wheels with slick tyres on his wide arch, not sure if he's baffled the sump??
Keep close tabs on this thread with a keen eye, loving the slicks - once you've ragged em about and got them up to temperature - you'll be amazed at the corner speeds & grip they produce!
I like how your car is evolving...
Welcome back Mr Hewitt
this car needs tb's.
