I'm about to bond a girdle on the underside of mine & just have it mounted through that - those o.e mounting's are utter garbage! (Even reinforced).
You can shave off that white mid bit from the lever too if you like.
There's another design of cables, with a bright yellow end rather than the white-ish end. I remember looking at them both side by side and thinking the yellow looked better and less slop although I can't remember why.
Nice installation though.
Thanks.
Ever since the subframe for the front clamshell was made it's annoyed me, it's not very easy to line things up, and the 2 pins it clipped onto were thoroughly dangerous. I decided it would make far more sense, as well as being lighter, if I relocated the towing eye and utilised that as the main means of support;
http://i285.photobucket.com/albums/l...ps6lpsqykk.jpg
http://i285.photobucket.com/albums/l...psmr7nvdjf.jpg
http://i285.photobucket.com/albums/l...ps3quhzgpw.jpg
http://i285.photobucket.com/albums/l...psme9nplzr.jpg
Who can spot the recycled Nova component I've used in the last photo above?
I'll neaten it all up and weld everything properly soon.
And this is all the old stuff I've done away with;
http://i285.photobucket.com/albums/l...pscfotdd4a.jpg
Looks far neater now and the tow eye can be removed in seconds, which will mean I won't bash myself on it when working in the pit.
Steering rack clamp?
Anti roll bar to tie rod bracket.
Did you find you dont need the counter weight thing on the selector at gearbox end on cable set up im getting one off a mate but the weight has broke off any way but looks like you have cut yours off ? Cheers .
And love that upg front end . if you ever decide to sell it pm me please
