aye lol go and tell Pete that he knows nothing, see how well that goes down lol
Tbh I was more Paul who said it in the first place. Negative Ba$tard!
the guy that put filler on and got it all wet should hang his head in shame.
Well I refitted the valves tonight and set the clearences :)
Only had to grind one shim to :D
Here is the Head built up..
https://fbcdn-sphotos-a.akamaihd.net...69485766_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...83516908_n.jpg
And my new Fancy Inlet, its a Td lower with a redrilled N/a upper and the inlet pipe extended. Look good and should flow better to :)
https://fbcdn-sphotos-a.akamaihd.net...04956128_n.jpg
As you can see it should flow nice.
https://fbcdn-sphotos-a.akamaihd.net...00098560_n.jpg
I Spent a while wire wheeling the lower half then I gave it a coat of primer.
https://fbcdn-sphotos-a.akamaihd.net...80505081_n.jpg
That will do for tonight I think.
You do realise Primer is just a porous as Filler. It rained heavily for 20 minutes, we sheeted the car down and afterwards I removed the sheet, took the photo and then dried it off and covered over with a PVC sheet and tape.
I can hardly prime the panel when its raining.
Me and the people helping with the build are experienced enough and qualified enough to know what to do in these situations and have done many other projects over the years! Thanks for the advice though.
Well yesterday I stripped my other shaft out.
https://fbcdn-sphotos-a.akamaihd.net...68767190_n.jpg
Wire wheeled one Cv, they both need painting now.
https://fbcdn-sphotos-a.akamaihd.net...41253744_n.jpg
And today I came home and finished all the front end of the welding. I.e. splash gaurds, towing eye and battery clamp stud.
Very happy about this :)
Here is a few pics :)
Splash gaurds..
https://fbcdn-sphotos-a.akamaihd.net...30810830_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...87006183_n.jpg
Towing eye nut..
https://fbcdn-sphotos-a.akamaihd.net...18478906_n.jpg
Clamp stud
https://fbcdn-sphotos-a.akamaihd.net...13912705_n.jpg
Hoping to get the welding done this weekend.. Fingers crossed!
Dan
Well Small update, Had the ode Man bead blast a few things for me,
Sump.
https://fbcdn-sphotos-a.akamaihd.net...33181375_n.jpg
I gave it a 3 coats of high heat silver, just waiting on a few other things from him then I can crack the spray gun out and do everything at once :)
https://fbcdn-sphotos-a.akamaihd.net...05039768_n.jpg
Dan
Oh and finished my inlet :)
https://fbcdn-sphotos-a.akamaihd.net...27487942_n.jpg
I told you that inlet would work :)
Looks good btw
inlet looks mega :) that other shaft still hiding?
lovely redness :)
cheers guys,
Lewis, I found it just after I got off the phone :)
Your certainly dedicated to the cause mate, more and more progress, slowly but surely it il be done n dusted! Keep up the good work :thumb:
Racing red ;) looking fab dan
lol where was it?
Cheers Guys :)
In my shed with all the rest of my Nova ****e lewis!! lol
lol sounds about right. amazing how much space a car takes up when it pieces aint it lol
Aye it does :P
well tonight I did a little more, finished one shaft :)
https://fbcdn-sphotos-a.akamaihd.net...58816975_n.jpg
I then pissed about with my new inlet and exhaust and took a few photos, what do you think?
https://fbcdn-sphotos-a.akamaihd.net...11534744_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...69678688_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...38746397_n.jpg
I personally love it and I think it should go well with the kind of look I am after.
Dan
Looking really good mate,you're getting there :)
Thanks pal :)
Did a bit more today, Painted my manifold and down/ up paint.
Fitted the manifold with new nuts and stainless bolts.
https://fbcdn-sphotos-a.akamaihd.net...96158818_n.jpg
Once the paint were dry on the down/up pipe I wrapped the top half.
https://fbcdn-sphotos-a.akamaihd.net...54479284_n.jpg
and inbetween that I fitted the injectors and glow plugs.
https://fbcdn-sphotos-a.akamaihd.net...49046754_n.jpg
Dan
over the past 3 evenings and this morn ive read nearly all of this thread and man there has been some graft on this.
when do you expect to have it back on the road?
rick
Dan, not trying to piss on your fire dude, but the down pipe might rott under that heat wrap, but heres a good way to try stop it, buy some more HT paint in white and spray it onto the wrap, this might keep it from getting to moist and stop the rotting effect etc.
Other then that dude, your one dedicated lad, and i envy your determination, wish i had the get up and go.
Looks awesome but could you not make a better flowing exhaust manifold? fabrication on this looks lovely though :)
Ricky: cheers Pal, I would like it at billing ?! maybe :P
Scott: I may spray it with VHT clear. or maybe black, dunno? Thanks anyway :)
Jake: the manifold looks like it will flow nice, and hopefully the down pipe will too. Its going to flow better than standard any way as the exhaust port is three times the size on the manifold now. Cheers any way :)
hats off you buddy :thumb:
shes getting there :)
Thank you Pie :)
Small update, the water cooler banjos for the turbo came today. All I need now is a compressor flange and to work out how the hell I will fit a waste gate :P lol
Cheeky Picture
https://fbcdn-sphotos-a.akamaihd.net...26152907_n.jpg
Dan
Well I did as Scott suggested, Looks cool tbh.
https://fbcdn-sphotos-a.akamaihd.net...76992393_n.jpg
Small bit more again tonight.
First of all I sealed my inlet and fitted the new stainless bolts I have acquired.
https://fbcdn-sphotos-a.akamaihd.net...84282889_n.jpg
I then did a small bit of cleaning of the strut gaiters and rack gaiters.
Before and after pic...
https://fbcdn-sphotos-a.akamaihd.net...67264153_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...45466405_n.jpg
Like new aye.
Dan
looking good. head looks amazing built up the the manifolds/turbo etc. This had better be at billing, if not i'm going to trailer it there for you lol
Cant wait to see this beast again. Last time i saw it, i was being towed through PVS in it lol.
I want to see you two racing down the strip come PV :thumb:
hope so :) you'll definitely see mine, and dans will be there on a trailer if not finished (he doesn't know this yet though lol)
