cheers mate, mite have to get some lolQuote:
Originally Posted by Plug
and good to see your getting to work on this, cant wait till its back out, mine will be MOT'd next thursday :)
Fancy selling me some headlight clips? :d
yea can do mate pm me your address ill get 4 sent up,
Should be out on this today just trying to find somewhere to blast off my crank bolt so i can drop it out and drop the head and block off to the machine shop.
looks like the front skin of your crossmember has seen better days :(
not thinking of fitting another one ?
not at the moment edd its extra money ive not got, and im thinking about cutting the middle right out anyway for the intercooler and welding in some box steel
ahhh right good idea
whats the plan then ? fitted the plating kit and have the bay painted ?
well today im trying to get somewhere to blast of the crank bolt so i can take the oil pump off and strip the block for the machine shop,
Then off to get some metal and hopefully pick up the welder tonight,
So then tomorrows plans will be plate, cut for intercooler and paint only hairy arseholing it thou for now i think
just received these through the post
http://i706.photobucket.com/albums/w...o/IMGP0209.jpg
Now all i need to order for the engine is an oil pump seal, water pump and piston rings,
Also can i reuse the crank bolts or shall i just get Gm ones? not getting arps for the crank as thats £100 odd i cant afford
Right got outside this morning and had a quick look over what i already had cut out for the intercooler,
http://i706.photobucket.com/albums/w...o/IMGP0210.jpg
http://i706.photobucket.com/albums/w...o/IMGP0211.jpg
http://i706.photobucket.com/albums/w...o/IMGP0212.jpg
Decided more needed coming out so i did this
http://i706.photobucket.com/albums/w...o/IMGP0213.jpg
http://i706.photobucket.com/albums/w...o/IMGP0214.jpg
http://i706.photobucket.com/albums/w...o/IMGP0215.jpg
Which left me with a big gaping hole lol in my crossmember,
http://i706.photobucket.com/albums/w...o/IMGP0218.jpg
Ive cut out as much as i can for the moment, Popped up to B&Q for some box steel, and im hopefully picking up a welder tonight so can get cracking tomorrow,
Seeing as i couldnt cut anymore off the car i cut the bumper backer so that i can fit the intercooler behind the bumper rather than hanging off the front
http://i706.photobucket.com/albums/w...o/IMGP0216.jpg
http://i706.photobucket.com/albums/w...o/IMGP0217.jpg
Seeing as there wasnt much else cutting wise i could do i decided to strip the bottom end and get it up the machine shop,
http://i706.photobucket.com/albums/w...o/IMGP0219.jpg
http://i706.photobucket.com/albums/w...o/IMGP0220.jpg
Crank and pistons out
http://i706.photobucket.com/albums/w...o/IMGP0221.jpg
then bare block
http://i706.photobucket.com/albums/w...o/IMGP0222.jpg
Fitted my xe inlet cam
http://i706.photobucket.com/albums/w...o/IMGP0223.jpg
and the oil pump needs a helicoil on one of the pickup bolts
http://i706.photobucket.com/albums/w...o/IMGP0224.jpg
Got that dropped off and awaiting its return
