Have a miss fire. Cant fix it. Grrrr.
When? Idle? On boost?
Was randomly when it wanted, now all the time.
split hose within breather dept...?
Nope all ok, it started off when just cold. It would hold back and bog down then clear. Nows its become a full on running on 2 wont rev or idle.
Coil or coil amp, also check leads at plug end, mine get oil on when topping up , Ialso had a prob with the connector at the bottom of the throttle body I have to wiggle it sometimes
Coil changed with my 2 spares, changed leads and changed to new leads, new plugs with gap checked
new dizzy cap and arm, new cts.
its cos its crying out for an f28 and p2 chips.
seriously tho, hope you get it sorted.
It probably be a sensor?
Youve changed the whole ignition system.
Like what Paul? I've unplugged the hall and afm to no change...
Doing a compression test to night on it as a just in case.
Si, f28 in garage and ph2 well maybe.
