Pics/vids of said dance required. Good to hear you're making progress, I can't wait to drive it (please!). :)
cool, nice dude - bet you can't wait!
i think it went like this lol
http://www.youtube.com/watch?v=uezJf...eature=related
Lmao /\ lol
Just got get the bastid running now!!!!!
what did you do file the blcok /sensor to get it sitting closer to the trigger wheel?
Filed the f**k out the sensor mate, hope the sensor never dies as i cba do it to another sensor!!!
If you look at the sensor, it has like a rib on it just before the flat edge where the bolt hole is, ive basically filed that totally flat.
what rpm is it reading on cranking? it will need to be over 300rpm before the injectors etc will try to fire if its anything like the emerald
Ive got the 2 green led's flashing on the ecu, 1 is coilpack out and one is injector output, Sooooo both the coilpack and injectors should be firing.
I was getting around the 200rpm mark, battery needs another charge though as i was cranking a while trying get it working with the metal crank sensor....
oh ok should fire up soon then :)
I can smell fuel around the bodies, so i think im either getting no spark, or its sparking at the wrong time
