The fit is fine on mine apart from slotting the rear mount. Which isnt an issue at all
I sold that dam steel mount as it's just crap! i used the standard Vaux one on mine..
How/what standard vaux mount did you use on an XE? :confused:Quote:
I think Scott means the actual engine mount not the bracket.
EDIT: OR is that what you both mean, & im just confused as to mount or bracket lol lol
Ahhh the bouncy rubber *******, not too sure as I've been in his car and I loved the rattle from the competition mounts, so unless he had it fitted once and then sold it, I am also confused lol
edit for mike: I meant/thought he meant the bracket, as it's the only all steel bit and he said "steel mount" in his car there was a definite engine vibration going on from competition mounts at combe last year.
As in the standard cast mount for the engine to chassis, not the actual engine Mount, as i still have solid rubber ones.
Engine to chassis goes through 2 parts, the bracket as mike is calling it (and makes much more sense and solves the whole confusion between the 2) and then the mount, i.e bouncy rubber GM thing, solid ally, TAS etc. I assume you mean the bracket (pressed btw, not cast :p), but then why do conversion mounts (brackets) exist if a standard gm one fits! :confused:Quote:
Dont know, as the standard fit better then them **** ones they sell.. lol
Some people remove the pressed bit attached to the chassis leg, lower it and weld it back on.
I guess the benefit of using brackets rather than moving the part on the car is you can revert back to a trusty smallblock if you want to :)
Here's the drivers side mount after an evening's tinkering. I filed it upwards so the hole is just below the top hole, then welded a fat washer over it, and filled in the original hole at the back. Job's a goodun, and the engine sits almost perfectly level (if comparing bottom of rocker to the slam panel)
http://iainel.co.uk/images/forums/NovaWIP2/807.JPG
Thats "proper job" Ian... top work.
Your mount looks better now its welded up.
oooo liking that muchly :)
Good work on the mount Iain
some top class work gone in to this keep it up dude!!
Gonna be some motor mate. :)
Not that exciting but might as well keep the updates as I go along...
Drivers mount in place:
http://iainel.co.uk/images/forums/NovaWIP2/808.JPG
Welded a thick washer to the rear mount too:
http://iainel.co.uk/images/forums/NovaWIP2/809.JPG
And beefed up the strengthening:
http://iainel.co.uk/images/forums/NovaWIP2/810.JPG
Perfec':
http://iainel.co.uk/images/forums/NovaWIP2/811.JPG
This hows how level it now sits side to side:
http://iainel.co.uk/images/forums/NovaWIP2/812.JPG
Looks fine dude, it's only a track Nova! lol
I want solid mounts, but id have to weld the rear one in as mines ripped clean out of the floor :(
Lol /\
Good work Iain, sits bang on now!
Nice skills on the mount Iain
Mounts look mucho better.
Yea top work iain keep it up.
Iain, I had to do this to one of my XE engine mounts, supposed to be made to sit level, mine was spaced in the end to make it sit right.
Usual good attention to detail! What's next big job?
Just read this from start to finish, Amazing work!
Cheers all. Started on the internal shifter so I can finish off the hole/welding on that, then the engine can come out and I can carry on with/finish off the rollcage.
Gear shifter is mostly sorted now! I think the engine can come out again now :)
Started out with a shifter with two kinks in the linkage end, so cut the bends out and welded it back straight:
http://iainel.co.uk/images/forums/NovaWIP2/813.JPG
Another issue I found was the end of the internal shifter was supposed to go inside the linkage (most other Vauxhalls seem to use this) so I tacked on the Nova end. Looks a bodge but this is just a mockup for now:
http://iainel.co.uk/images/forums/NovaWIP2/814.JPG
On to the car, I started drilling holes and found where I had welded over the hole I had left a gap between the 2 layers - pretty rubbish but this was the first bit of metalwork/welding I did on the project almost a year ago! Anyway I stood and looked at it, and thought it leant itself well to the nuts staying inside the car!
http://iainel.co.uk/images/forums/NovaWIP2/815.JPG
So welded those bad boys in:
http://iainel.co.uk/images/forums/NovaWIP2/816.JPG
Factory fit lol:
http://iainel.co.uk/images/forums/NovaWIP2/817.JPG
Shifter hole needed enlarging MORE - it's huge now!
http://iainel.co.uk/images/forums/NovaWIP2/818.JPG
But it's in and gets a couple of gears :):
http://iainel.co.uk/images/forums/NovaWIP2/819.JPG
Hooked up to my rosejointed linkage:
http://iainel.co.uk/images/forums/NovaWIP2/820.JPG
Look at you with your god damn captive nuts! lol
Looks well though, neat job.
That RJ linkage looks dirty though, sell it to me and make yourself a brand new one :)
Finished most of the 'mockup' now - seating position feels okay with the Corsa steering column and Cav shifter (which feels AWESOME with the rosejointed linkage):
http://iainel.co.uk/images/forums/NovaWIP2/821.JPG
Seat sits nice and low, which is good for a tall person!
http://iainel.co.uk/images/forums/NovaWIP2/822.JPG
Also trimmed my bonnet to clear the XE rocker cover, swiss cheese f/g bonnet lol
http://iainel.co.uk/images/forums/NovaWIP2/823.JPG
Engine can come out now and I can finish the rollcage off, at least I know it'll all bolt together easily now when it's painted :)
Good work.
Could you not have clinch/riv nutted the shirt box down?
Iain I've just read this thread all the way from start to finish, again, for what must be the 10th time
You keep inspiring me to work on mine again every time i read it :D
Awesome work man, nice to see someone doing a propper DIY job, and making a good job of it.
Benn yeah I could have used a rivetnut if I knew they existed!
Cheers Matt :) Wait till see you see it in person before saying I've made a good job though lol
We have passenger triangulation lol All notched just need to weld it up and start on the drivers:
http://iainel.co.uk/images/forums/NovaWIP2/824.JPG
http://iainel.co.uk/images/forums/NovaWIP2/825.JPG
http://iainel.co.uk/images/forums/NovaWIP2/826.JPG
Total weight of both bars = 2.85kg, not too bad!
Looking good dude.
Good work Lionel
love it long time
Stop ****ing around and get this thing back together! lol there wont be any track's left for you to run on by the time your finished! lol
Tops though dude..
Most of the triangulation is welded in now. Just the plating to do on the drivers side bulkhead left.
http://iainel.co.uk/images/forums/NovaWIP2/827.JPG
Stitched to the turret and side:
http://iainel.co.uk/images/forums/NovaWIP2/828.JPG
Bit of neat welding on the front leg:
http://iainel.co.uk/images/forums/NovaWIP2/829.JPG
Rest of the welding looks crap but oh well lol:
http://iainel.co.uk/images/forums/NovaWIP2/830.JPG
You can see where it's tacked to the front splash guard:
http://iainel.co.uk/images/forums/NovaWIP2/831.JPG
And an additional brace between the B pillars should help in the event of a side impact:
http://iainel.co.uk/images/forums/NovaWIP2/832.JPG
http://iainel.co.uk/images/forums/NovaWIP2/833.JPG
You're Sh1t!
Oj
Looking good Iain! <3
