Cheers those comments - good thinking.
One of the other serious issues that has emerged from the brake change has been the heat generation. We've measured the temperature of the brake and general hub area as being well into the mid 600 degrees C :eek: . The readings may not be that accurate (although we have tested on other things and it seems ball park)but nevertheless whatever, it's still hot enough to allow the wheel bolts to stretch loose. After 2 or 3 fast laps we need to get in to tighten them and then if you dont loosen them before they get cold they wont come undone again.
I should imagine that these temperatures are having fairly significant effects on the bearings etc etc seeing as its all std stuff and not designed to be cooked up at this heat.
Looking through brake fluid specs there is only one fluid that seems like it can live with this temperature - the DOT 5.1 Castrol DTF (? IIRC) so we will have to change to that which could well help cut brake fluid boiling and thus overall brake feel.
The big change that I need to make on this whole subject is to sort out some kind of forced ventilation to the brakes but it wont be easy - there's not much room around front wheel drive hub assembilies:confused:
