Mate, do they hub unbolt on the manta rear axle like sierra ones do?
Isn't that a Manta B rear axle? Isn't it going to be too wide?
You have 4 nuts securing the bearing plate, you can get to these through the holes in the hub.Quote:
Then pull out.
So pretty much the same.
in answer to your "to wide", over on retro rides, a guy has been advising me on what to do about it, its ok, it just limits me to what wheels i can run.
or put on ****y arches lol.
Originally Posted by chimp007_uk
So bearing plate comes off like sierra then hub is held into bearing plate. Does the hub allow a splined shaft to pass thru it I take it? How easy are they to convert to disc rear?
Any chance you could measure something for me bud? The distance between the bolt holes on the bearing plates. Hoping they're the same as sierra!
so the 4 bolts, which hold the backing plate to the drum, onto the axle?Quote:
ill do it today :)
Yeas mate, I think so! lol Its my understanding the hub goes into a bearing carrier which then is held onto the axle by 4 bolts. Maybe you could take as many pics as possible of the setup? Much appreciated.
i can post the relevant pic from the manta haynes tonight if you wish?
Please mate, more the better!Quote:
Originally Posted by Sloth
If its inappropriate to post the info I've requested in this thread please put it in my project thread.
