I wouldnt of had to if i had a shorter alternator belt, its just with the alternator being on a pivot kind of bracket, if lifts up as it moves back....
Easy solution though :cool:
Go-Tech loom is now sorted and all spot on accoridng to the multi meter. Just got the loom fitted in the car, layout seems spot on, so im happy :)
Just need to actually wire the loom into the car tomorrow and mount the ecu somewhere. Probably bolt it to the underside of the dash, or around the roll cage leg :)
Oh and need wire up some relays too, one for fuel pump, one for ecu 12v, and tother for rad fan. :d
Sounds good, weirdly looking forward to a power figure even though experience means its probably within 10bhp or so of my guess :P
Which is?!
Which is ZERO atm lol
Having some issues, the GoTech isnt getting any rpm signal when cranking. I know the crank sensor works because its the same one ive always had....
Apart from that issue everything is spot on, tps/air temp/cts all look acceptable figures, fuel pump comes on with ignition etc.
Its just not going to do a lot if it thinks the engine isnt being cranked.
HMMMM, not sure what to try TBH
hmmm been there mate lol.
mine fired today; see electrical in technical
ill have a think about that cranking prob
I THINK i know what the issue is.
Had a search on mig and turns out another guy was having the same problem, he had to file down the crank sensor bracket to get the sensor sitting stupidly close to the trigger teeth. Easy solution on a small block because its all externally mounted...
That sorted his problem straight away.
Not so easy on a xe where the crank sensor points inside the crankcase and bolts to a cast iron block:cry::cry:
Bugger.... :wall:
Cant you shave some off the bottom of the sensors case?
I had this problem too, dont file your crank sensor we tried this, ended up buying a new one. after some further research it turned out it needed re flashed with new firmware.Quote:
Originally Posted by Adam
This was the reason I didnt make pvs 08 lol
