painted wing bolts = WIN.
De-chromed bonnet lifters = WIN. (just 1 step left to ditch them all together)
The RS turbo plugs we told you about are gen FORD ones mate. Not NGK's.
Nice work Benn, my bonnet lifters have started getting some rust at the tops, need to sort them too.
is that a vectra st wheel i spot next to the bumper, i need one lol
Yes yes, wont ditch them tho, nice spec and hate bonnet stays, they look so messy. Plug i wanted to try out first, when i started it earlier it seemed better. But wanna start it early in the morning so its still proper cold to test it. If it fixes it then i'll look in to Ford Plugs. You'll be happy to know i gapped them too..lol And posted you a box of goodies on Friday.Quote:
Astra Dan did his for a more factory look, and that works and looks nicer too.Quote:
Originally Posted by Nova_Tek
Yes its a bent one. Wanna use it to test to see how much a 7J rim will rub..Quote:
you will need a 10 mm spacer on the front, not sure on the back will let you know tomorrow.
i have a bent one too so need another :(
Why a spacer? Touching the leg?
Nice work dude..... when it comes to subtlety the wing bolts tone down the bay a hell of a lot when they arent chrome/zinc hence why I kept mine painted. Never got on with bonnet lifters as they seemed to alter the bonnet gap with nova hinges being so weak... Lastly Ill leave you with this........ ;)
http://i84.photobucket.com/albums/k2...g?t=1278240696
Nick.
if your not on coilovers on the front you havent got a hope in hells chance, the wheel hit on my gaz coilovers hense the reason for the spacer. pics in my thread :thumb:Quote:
Couple of layers of cling film on your bumper for the drive down to billing for an anti-stonechip protection layer FTW:thumb:Quote:
So cracked on, time to swap wheels to the shiney ones for VBOA at Billing. While doing it i did...
Cleaned and waxed and sealed inner arches,
Check my new brake lines,
Change my disc and pads too.
Finished re-routing the water return..
http://img.photobucket.com/albums/v3...llingprep8.jpg
Found i had a CV boot gone a month back, then at the mot noticed a bronze patch on my disc and the tester said it was pulling to that side a bit.. Tried cleaning the pad and disc. But CV grease had got in there good style and killed both. So fitted new M1144 Mintex pads and a new disc..
http://img.photobucket.com/albums/v3...llingprep4.jpg
Hhmmm must have a stiff chassis... lol :roll:
http://img.photobucket.com/albums/v3...llingprep6.jpg
Inside of the disk and dead pad...
http://img.photobucket.com/albums/v3...llingprep9.jpg
http://img.photobucket.com/albums/v3...lingprep10.jpg
Car back on the ground, had to pump this tyre up as the slim line alloy jack wouldn't come out from under the sill... lol
http://img.photobucket.com/albums/v3...lingprep12.jpg
Flatted the primer on my bumper off, flatted my boot grab off as it fot damaged when the boot opened in the garage..
http://img.photobucket.com/albums/v3...illingprep.jpg
