Originally Posted by
C612DNM
			I use an OBP floor mounted box in my Belmont V8 Thundersaloon. That has reverse mounted master cylinders, and requires a false floor. Took a bit of getting used to as my feet are something like 4-5" higher than they were with the old Gp.4 Escort pedal box that I used to use.
Being a Thundersaloon and built for two/multi-driver races, the seat is on runners, and I have to run it almost right back. That also meant running a longer/extended steering column, and all the issues that go with that. I still have lots more to sort in that area - going to fabricate a new column at some point to replace the "spear" (as on series organiser calls it) that I currently have.
I can certainly recommend the OBP pedal boxes. Very good - beware of fakes/imitations though -it seems that there are cheap (and poor) Chinese copies appearing in the market.
They do a wide range of bulkhead mount ones too.
