Why didnt the head go in the hot wash?
Ran out of time so i just did a quick clean off until i get the timeQuote:
You need to put £15 in the meter to run the machine?
Evening everyone i have a small update for you
There was a slight issue with the hubs i got off MK999, that issue being one looked like this
Normal
http://i248.photobucket.com/albums/g.../NovaTD607.jpg
The other one looked like this
Unwell
http://i248.photobucket.com/albums/g.../NovaTD588.jpg
Someone appears to have tightened a nut on to the cv joint with out the washer and mangled it so on to the lathe
http://i248.photobucket.com/albums/g.../NovaTD618.jpg
The first run to remove the large bur
http://i248.photobucket.com/albums/g.../NovaTD621.jpg
Tiding up the damaged splines
http://i248.photobucket.com/albums/g.../NovaTD620.jpg
Getting there
http://i248.photobucket.com/albums/g.../NovaTD615.jpg
All done and looking a lot neater - much better
http://i248.photobucket.com/albums/g.../NovaTD619.jpg
Then from the lathe to the press
http://i248.photobucket.com/albums/g.../NovaTD617.jpg
Finally the hubs reunited with the carriers, job done.
http://i248.photobucket.com/albums/g.../NovaTD623.jpg
Uh oh, supplying dodgy goods :eek: lol Not giving you a refund though :p
good work, i love the daily updates :)
Wicked updates again James.
Nice lathing. Rears didnt need taking down then...
What? if you mean the part of the hub that presses into the bearing then no they had already been done (badly i will add lol)Quote:
Did you paint the flanges after you bead blasted them matey?
Pretty sure they will go rusty immediately if you didnt! lol
