You BIG tart all that hard work doing wheels nuts up by hand! lol lolQuote:
Now i will have to get one!
Any thoughts on how to get my bonnet staying flat on track James?
And no... slowing down isn't an option lol
You could just do as you did with the rear screen....that layed flat enough on the track once it had fallen out lol lol
lmfaoQuote:
Get a flat steel/alloy bar from b&q, and attach that to the underside of the bonnet edge...Quote:
On serious note that might work but you were going to try that at the start anyway weren't you?Quote:
Originally Posted by Adam
Could always stick another bonnet pin in the middle, might look a bit odd, but it'll do the job.Quote:
Originally Posted by shaun larnder
What you on about Larnder? Its nearly finished! Just needs a lick of paint.lol
Should work fine, could drill two holes through the bonnet and metal bar, and then just nut and bolt it solid....Quote:
Wont flex at all then
What manifold are you using? Because i'm thinking of getting an ashley exhaust like yours. I'm using a standard c20xe manifold and was wondering if i'll need to change the lengh of the exhaust aswell as the angle? Where did you get yours from? Hope you don't mind all the question. Nice project by the way, like the work that gone into it.
