The adjuster platforms have seized solid. So the only way to change the height is guesswork with £60 a time springs....... :(
Un-seize them, dip them in wd40/penetrating fluid then use a funk off big wrench to move them for wards and back wards till they free off.
Then coat the adjuster and threads in grease or copper slip...
No good? http://www.rallydesign.co.uk/index.p...stijfm3vh5p1v7
cut the old ones off
Side strips are clipped on mate, slide them off.
I can get new platforms from AVO for £8 each, but getting the old ones off without damaged the threads may be tricky
John, cheers mate. They will be staying then, cba messing about filling holes up.
but then hole-io'sQuote:
Originally Posted by John H
Just grind the tips off?Quote:
Originally Posted by peester
its rivets holding the clips on
watch ya dont slip then lol
oh so theyre arent any holes , to fill..?
If you'll be running shorter springs it wont matter cause the new adjuster will be higher up.Quote:
Originally Posted by Adam
But cutting it carefully and you should be ok. Do try what i said up there ^ grips and a hammer after dipping.
