side strips are stuck on, why you thinking of going back to telescopic's?
I want some shorter springs, but cant adjust my coilovers.
So might just get some low "normal" springs and use them instead.
That way means im not going having problems with the Mo's rubbing the coilover spring, as they are wider than my current wheels....
fair do's.
cool, sounds more track-focused plans.. i do like innocence of the std look it has, but i understand u might be getting bored of it now..
Engine management: you going cheapsquirt or designer label..? new??
Got my eye on some semi-designer management, 2nd hand ;)
Not megasquirt or anything like that.
liking the plans! get the bodies on there you wont look back
cool thats good. Well if u need anything to do with wiring/ecu's/bits u can do a lot worse than to contact Steve @ GWR Motorsport
Cheers :)
Just semi tub & turret the rear mate & move the shock mount in slightly
Why cant you drop the back if its coilovered?
