Originally Posted by
maddogdaz666
			Found out today a simple engine swap wasn't so bloody simple.
X14xe from a mk4 Astra that I've bent the valves on, isn't the same as an x14xe from a tigra/Corsa b. I've had to swap all the timing end for the engine mount, and then found out I cant fit the Astra rocker cover to the tigra head as it mounts differently, which I kind of need as the Astra runs a coil pack and the tigra runs a separate coil and HT leads.
And then even worse then that...I CAN'T FIND MY ANGLE GRiNDER :mad:
