Very nice,
Two questions...
Have you sourced any rebuilb parts for the engine, if so where from?
And what are the shafts off (are the welded ones) , what Gearbox you using?
Keep up the good work !
Dan
Very nice,
Two questions...
Dan
Thanks again for your kind words everyone - putting crusty old crap in the blaster and seeing it come out spotless still hasn't lost its appeal lol
Dan yes i have managed to source all the rebuild parts but they weren't cheap
The bearings ~( an engine set of bigs and mains), piston rings, and thrust spacers cost £108 from a local engineering company we use through work (Robinsons engineering in ferndown dorset)
Then for the fixings i had to go to vauxhall (Robinsons advised me to go to vauxhall as thats the only place that supply them ie they aren't available n the after market)
The Main bearing cap bolts are re usable according to auto data (which is a spot of luck as vauxhall don't list them as they are supposed to be reused so arn't available at all according to vaux parts dept) so i only got the con rod studs and nuts (8 or each) for £45
I was going to go ARP but they are a strange size some thing like M9 super fine so i thought OEM for now.
BTW i also enquired with vauxhall about the bearings and they come in pairs at £27 a pair!! :eek:
you living back in MK gayboy?
No mate only on weekend visits atm until we are in our new house (hopfully soon) nice to see you making an apperance is all ok?
It would be nice to catch up soon
Craig have you still got the red grill?
yeah mate.
Painting looks good.
Cheers boss like I saidits only rattle can
Few more bits done today
Hubs hand shot with the fine grade
http://i248.photobucket.com/albums/g.../NovaTD597.jpg
And polished up
http://i248.photobucket.com/albums/g.../NovaTD584.jpg
Hub carriers painted up
http://i248.photobucket.com/albums/g.../NovaTD604.jpg
More bits cleaned ready to be blaster
http://i248.photobucket.com/albums/g.../NovaTD589.jpg
They cam out spanking as usual
http://i248.photobucket.com/albums/g.../NovaTD599.jpg
Especially the upper half of the sump
http://i248.photobucket.com/albums/g.../NovaTD600.jpg
http://i248.photobucket.com/albums/g.../NovaTD606.jpg
Primed the filler neck and lower half of the sump (the pan if you will)
http://i248.photobucket.com/albums/g.../NovaTD601.jpg
http://i248.photobucket.com/albums/g.../NovaTD596.jpg
Oil strainer and oil pump degreased and hot washed
http://i248.photobucket.com/albums/g.../NovaTD586.jpg
No swarf left in here now :roll:
http://i248.photobucket.com/albums/g.../NovaTD594.jpg
Oil pump stripped and cleaned - by hand this time i will add
http://i248.photobucket.com/albums/g.../NovaTD612.jpg
Starter cleaned off
http://i248.photobucket.com/albums/g.../NovaTD610.jpg
Then on to the head - which was filthy
http://i248.photobucket.com/albums/g.../NovaTD592.jpg
http://i248.photobucket.com/albums/g.../NovaTD593.jpg
I made sure i gently removed the injector washers first (there are two per injector)
http://i248.photobucket.com/albums/g.../NovaTD585.jpg
http://i248.photobucket.com/albums/g.../NovaTD603.jpg
For reference the small washer goes this way up in the hole
http://i248.photobucket.com/albums/g.../NovaTD587.jpg
In the degreaser
http://i248.photobucket.com/albums/g.../NovaTD591.jpg
Looking better after a rinse
http://i248.photobucket.com/albums/g.../NovaTD595.jpg
http://i248.photobucket.com/albums/g.../NovaTD602.jpg
http://i248.photobucket.com/albums/g.../NovaTD611.jpg
http://i248.photobucket.com/albums/g.../NovaTD598.jpg
Then after a dry off with the brake cleaner and air line i lubed up the cam and followers
http://i248.photobucket.com/albums/g.../NovaTD605.jpg
Some new goodies arrived to day as well
http://i248.photobucket.com/albums/g.../NovaTD609.jpg
:thumb::thumb:
