kissey dave, i swapped the leather and foam from the cally seats onto a 1 peice corsa back, which it fits perfectly. the base is tie wrapped in. tania makes orthotic footwear for a living and has some natural shoe polish that also feeds the leather. thats just 1 coat btw. i use an old sock, like a glove and just got busy with it. :thumb: mums offered to sort the split in the drivers seat after pvs. she was an upholsterer and seamstress.....:d
right small update, flash tested and the ecu say crank sensor, so im gonna try an old one i have here....
IF you need one, let me know as I have 13 though of them.
flol, fitted my spare, and it fires but wont run. so i checked the fuel pump just in case, and the tank.........
is dry. i am a tard...
update.
put some fuel in it, and it fired straight away. and revved fine. then i noticed the oil pressure light on. oh noes, so i looked at the engine bay, revved it at the throttle body and the bottom end is knocking. like a ****. so i looked at the dash, revved it to 4k and it goes out, but as soon as you let off it comes back on, at which point i shut it off, packed up and came inside. i have no idea and tbh i dont care.:witch::mad::mad::mad::cry:
indeed mate. i dunno whether to break or get another motor.
thats what happens when you try and build on a budget imo
surely another bottom end can be sourced easily enough
Just stick the head on another block
