We should all know the traps by now eh so quite right, thinking about doing the same with mines to aid preservation ;)
Yeah you might as well Pal. I have done no end like that on mine. the front outriggers are all smoothed into the slash guard for example.
progress is looking good! Wish i had the same motivation at the moment.
Cheers Gary, I have the odd hour here and there, its all the nice project threads on here that keep me going. :)
Update time.
Well first of all I made a plate for the boot corner.
Offered up.
https://fbcdn-sphotos-a.akamaihd.net...20930689_n.jpg
While I were there I noticed the towing eye only had a few spot welds. So thought I may aswell seem it :)
https://fbcdn-sphotos-a.akamaihd.net...05547536_n.jpg
Then I welded the plate in, this is the underside.
https://fbcdn-sphotos-a.akamaihd.net...16823258_n.jpg
And from the top.
https://fbcdn-sphotos-a.akamaihd.net...94683524_n.jpg
Corner view.
https://fbcdn-sphotos-a.akamaihd.net...38599117_n.jpg
Ground it all down abit to :)
https://fbcdn-sphotos-a.akamaihd.net...10228217_n.jpg
My new 'trimmed down back panel :D
https://fbcdn-sphotos-a.akamaihd.net...55999790_n.jpg
Quick cover of primer.
https://fbcdn-sphotos-a.akamaihd.net...11792974_n.jpg
The other end of the panel were then welded up.
https://fbcdn-sphotos-a.akamaihd.net...09392348_n.jpg
I quite like the new shape...
https://fbcdn-sphotos-a.akamaihd.net...21357318_n.jpg
So thats the back panel done :D.. on with the N/s/f cross member.
Cut the lower half of the leg out for two reasons. one because there was a small bit of rot and I wanted to be sure there were no more and the other being I want to tie in the cross member like I did the other side for strenght and to remove the silly water traps...
https://fbcdn-sphotos-a.akamaihd.net...93691108_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...24744411_n.jpg
Just need to plate it up now :)
https://fbcdn-sphotos-a.akamaihd.net...56081649_n.jpg
I also removed the servo and brake pipes.
https://fbcdn-sphotos-a.akamaihd.net...21456348_n.jpg
And this is how she is looking .. Nearly half way through the welding too so I am excited now.
https://fbcdn-sphotos-a.akamaihd.net...80687120_n.jpg
Anyway thats it for today folks :)
So Monday morning I started working on the ode Nova again,
Made the plate for the Chassis Leg
https://fbcdn-sphotos-a.akamaihd.net...63293075_n.jpg
Welded her on :)
https://fbcdn-sphotos-a.akamaihd.net...73648578_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...59334337_n.jpg
Had a little rot on the top of the Cross member so cut that out.
https://fbcdn-sphotos-a.akamaihd.net...13746438_n.jpg
New Piece welded on :)
https://fbcdn-sphotos-a.akamaihd.net...23988055_n.jpg
Made a small strengthener for the bottom of the leg and welded it on.
https://fbcdn-sphotos-a.akamaihd.net...29793060_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...20975861_n.jpg
I then boxed the front in.
https://fbcdn-sphotos-a.akamaihd.net...09343729_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...91255433_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...51383743_n.jpg
And after a quick coat of paint to stop the rain getting in.
https://fbcdn-sphotos-a.akamaihd.net...08541247_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...27704357_n.jpg
Just need to make the other wing mount bit and the front will be then done. Next Job is to cut the turret out like i did the other side as I know its been welded before and it don't look that neat so I want to be sure its strong and do it again :)
this must be one of the only threads on here that get updated every day fair play mate its getting there should be mint when done. stoped updating mine as no1 even looked lol
Thanks dude :)
Received a few more goodies for the turbo today. Should be making the manifold soon.. :)
Will add a picture or two this weekend :)
Dan
Well did a bit more today, had a couple of mates to help out so we got plenty done.
I cracked on with the N/S turret
Chopped all the suspected areas out.
https://fbcdn-sphotos-a.akamaihd.net...79681268_n.jpg
Mean while Rob removed the fuel Tank and rear beam.
https://fbcdn-sphotos-a.akamaihd.net...23650133_n.jpg
I bolted the brace on to steady the Job up a bit..
https://fbcdn-sphotos-a.akamaihd.net...93204455_n.jpg
First bit of welding, again 2mm plate
https://fbcdn-sphotos-a.akamaihd.net...46389594_n.jpg
Second bit, chassis leg top only.
https://fbcdn-sphotos-a.akamaihd.net...18580998_n.jpg
The ream beam
https://fbcdn-sphotos-a.akamaihd.net...04888091_n.jpg
So any way, we thought we would offer up the new turbo..
Old on top
https://fbcdn-sphotos-a.akamaihd.net...35188875_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...61667123_n.jpg
And roughly where it will sit.
https://fbcdn-sphotos-a.akamaihd.net...96742546_n.jpg
I will need some kind of log manifold to be made.
https://fbcdn-sphotos-a.akamaihd.net...32071507_n.jpg
I then tied in the chassis leg and arch top. I want a smooth bay So I have done it like this for minimal filler.
https://fbcdn-sphotos-a.akamaihd.net...09234300_n.jpg
This piece is actually a nova rear seat base.. Recycle aye :) The possibility's are endless!!
https://fbcdn-sphotos-a.akamaihd.net...28234621_n.jpg
Quick grind down and some primer to keep the wet out.
https://fbcdn-sphotos-a.akamaihd.net...28580855_n.jpg
Then on with the back of the turret
https://fbcdn-sphotos-a.akamaihd.net...44940799_n.jpg
Poor old Ryan spent the day removing the underseal from the rear arch.. looks pretty good bless him..
https://fbcdn-sphotos-a.akamaihd.net...60745668_n.jpg
And then Rob removed the rest of the fuel lines and brake pipes so now the shell is bare underneath.
https://fbcdn-sphotos-a.akamaihd.net...19107413_n.jpg
I then had a go fitting a K-series manifold, lines up well and with some work I think I might be able to mount the t25 on it..
Will have to wait and see, any way here is a photo to show how good a fit it is.
https://fbcdn-sphotos-a.akamaihd.net...32885935_n.jpg
That's all for today any way folks...
Dan
looking good :) just the other sill and arch to do now then yeah?
I spot a slight problem here, I trust you've fixed it lol
Remember I want that lambda sensor back in one piece too :thumb:
No not yet but I will lol.
Certainly going to town on this fella, good work :thumb:
i'd probably forget untill i painted it lol
Nahh I wont forget, turbo should fit nicely btw. If I give you the gasket could you sort out the flange please :)
good, that manifold looks pretty good tucked in there.
yeah no problem, I'll see if i can get hold of mark on monday.
I also want the cat part of that manifold back, seeing as I gave you it lol
You can have it, but you do no its a steel pre cat, well robs were any way. So worthless..
i wish i had your motivation lol
i want mine done for national weekend but i also said that last year lol
I want mine done for PVS, anything before that is just a bonus lol but then I only have a weekends work to get it done. Now Mr Ball on the other hand... lol
ive only got about 5-6 days worth of work and it'd be finished
we both need to get on with it then lol Dan will still finish his before me though lol
As it is Saturday I did a bit more to the ode Nova..
Cracked on with the N/S Turret.
Made a plate up and welded it in at the back between the turret and loom hole.
https://fbcdn-sphotos-a.akamaihd.net...43200412_n.jpg
This is a close up of the engine side, where the Servo would be
https://fbcdn-sphotos-a.akamaihd.net...29760570_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...66652819_n.jpg
I then cracked on making the inner of the outer bit.
Seemed and Plugged.
https://fbcdn-sphotos-a.akamaihd.net...14755198_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...21005661_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...51334839_n.jpg
A quick coat of paint to cover her up.
https://fbcdn-sphotos-a.akamaihd.net...63252655_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...86200185_n.jpg
Once the welding is all done I think I may blast the hole bay then just prime it all at once. Would make life easier.
Also removed the Passenger Door.
That is all for today though.. it were to cold. :(
Aye your definately well practised in the art of welding mate, i had my 1st attempt today on the GTE Reshell and its certainly not as easy as it looks :eek:
Keep up the good work :thumb:
Lol, I have a few tips in welding car, as they are so different to proper metal lol. Pm me if you like
Its not now
Well I braved the cold yet again, Finish my front strut/torret/ inner wing..
Basically made some spacers to move reinforce the torret mount or what ever you want to call it.
https://fbcdn-sphotos-a.akamaihd.net...71167805_n.jpg
Then I made this to go on top, exactly the same as the other side.. should be very strong indeed :)
https://fbcdn-sphotos-a.akamaihd.net...53273542_n.jpg
From above..
https://fbcdn-sphotos-a.akamaihd.net...62649416_n.jpg
I then wired wheeled the rest of the underseal and brush painted the inner arch with Zinc primer, once it were dry I went round the edges with etch primer. They will all be seemed sealer and spray primed, stonechiped, then gloss painted with 10l 2k once eventually :)
https://fbcdn-sphotos-a.akamaihd.net...16004873_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...92564473_n.jpg
I cracked on making the wing support like the other side then drilled all the new holes to mount it :)
https://fbcdn-sphotos-a.akamaihd.net...02351872_n.jpg
and the wing fitted...
https://fbcdn-sphotos-a.akamaihd.net...98857508_n.jpg
As the cross member was now finished I decided to drill the holes for the rad and tie bar mount, then I gave it a good wire wheel and primer. The Inter-cooler mount do need moving though, but that is a job for when I can actually fit the bumper etc.
https://fbcdn-sphotos-a.akamaihd.net...46181159_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...57510602_n.jpg
And How I left it. Definitely getting there now :), just front chassis legs, sill and both arches to do :)
https://fbcdn-sphotos-a.akamaihd.net...39488533_n.jpg
Shes definately coming along mate, although you might need another engine to pull all that metal you putting into it lol
I think you would be surprised how heavy the rust is I have removed. I will weigh the car when its done, can't see it being much heavier tbh. But I don't really mind as long it is strong :)
Bloody hope so Kev :)
Fair play dan keep cracking on lad will soon be summer so pull your finger out lol looking good though lad!
