Could really do with your help guys as stated in the previous post, here's a more detailed picture, didn't realise how blurred the last ones were
http://i69.photobucket.com/albums/i4...704_182832.jpg
Not a hard fix. Cut out the middle (green bit) Clean all the sides up then put a flat plate in there. On the top (in the boot) cut the metal back so you can see in the chassis leg, as i bet that's rotten too. Then you can work out if you need to remove the end and replace. Then weld a flat plate in from the top over the holes. Joining bottom and top plates.
http://img.photobucket.com/albums/v3...psdc740e34.jpg
Not that bad, ashamed to say i had to do the same in mine. Due to the sunroof drain being blocked.
Thanks Benn... I knew I could rely on you for a reply. I know where needs cutting and replacing... My problem is getting in there to cut it, I can't get my grinder in there enough to make a neat job.
i use a dremel with small cutting disc. takes a while and a good few discs.
http://www.nordicskiracer.com/equipm...g/dremel01.jpg
Cut what you can out, then grind the rest to 1 remove left overs, 2 clean up for welding.
Grinder, or a belt sander. One of the best tools i own.
I made plates up like this... They dont look neat there, but everything with trimed and made nice.
http://img.photobucket.com/albums/v3.../Welding22.jpg
http://img.photobucket.com/albums/v3.../Welding24.jpg
Cheers guys, I got there in the end, I took the guard off my air cut off tool, made things easier, the rest was threatened with a mahoosive chisel. Made a template with a cheerios box and bobs your uncle.
http://i69.photobucket.com/albums/i4...705_142708.jpg
http://i69.photobucket.com/albums/i4...705_142727.jpg
http://i69.photobucket.com/albums/i4...705_155757.jpg
http://i69.photobucket.com/albums/i4...705_155821.jpg
Good work, looks awkward and annoying lol
The front end fit is very good for a Nova, I spent hours trying to get mine half as good as that!
Now looking at this, what was the chassis leg like under? As it looks a bit crispy... Unless it's just the pic....
