I thought I was the only one that used that word... lolQuote:
Originally Posted by peester
good work Benn.
good work Benn.
Benn do you have any clearance issues with the turbo wheels?
Hi Benn
Dont mean to pick faults but the power feed for the fuel pump should go down the passenger side then through a small gromit in the boot strait to the pump.
Apart from that great work as normal..
You shouldn't see anything with a blow in, but being black will make it harder. I'd get the roof painted to be safe.Quote:
Originally Posted by Jeff16v
Cheers Craig.
Only cause i've made it low. Remember turbo rims are the same size as Speedlines.Quote:
Originally Posted by corsagsi16vplym
Why? You'd be running it right the way under the dash then.. My way it comes out of the fuse box and down the sill. The gromit under the seat pan is the only one that goes to under the car.. And it runs with the battery cable and stays away from the speaker wires too.Quote:
Originally Posted by Ernie
benn, gen me up on how you fitted your fans mate, ive just got the same ones in twin 9" but only came with the plastic clips as if you were to screw it into something, should there not be some sort of racket tie type fixing that feeds through the rad fins?
***EDIT! found the problem, extra fitting kit also required, would have been handy to have that on the advert! will struggle to get them in place for 1/4 mile action on sunday now!
ps. good work as always!
Mine push thru the holes on the fan, thru the rad. On the back you should have a square bit of plastic with a hole in it, that slides down the plastic finger thing.
Like a cable tie..
Cars in the bay all masked up ready to be painted in the morning.
looks good in tv this month matey lol!!
Cheers dude, they took a load of pics..
Has this just been featured then? TV will probably be out tomo then for me.
yea you not got the mag yet?? looks nice as allways mate!!
