Sat morning the roof was check then had a light skim of stopper over the welds as it was perfect. The the whole roof was high build primered.
http://i6.photobucket.com/albums/y23...n/IMG_8933.jpg
Spent this evening flatting the roof off. One thing i hated about working in the bodyshop was flatting off primer, its a hateful job and i really hate it. Did it all with a long block to make sure its ripple free.
All ready for paint now.
http://i6.photobucket.com/albums/y23...n/IMG_8954.jpg
http://i6.photobucket.com/albums/y23...iringloom2.jpg
Wanted to re wire my fuel pump for a while, as it was done quickly the first time and wasn't very neat at all.
Dan was able to find me some wire.. See "some" to be enough to do 2 Nova's.
http://i6.photobucket.com/albums/y23...iringloom9.jpg
Nice and thick core.
Untidy and badly run,
http://i6.photobucket.com/albums/y23...ringloom12.jpg
Had 3 joins in too..
http://i6.photobucket.com/albums/y23...ringloom13.jpg
No the plug wiring had been cut and joined from the guy before.. It was very badly done. It fell off the crimp when pushed out..
http://i6.photobucket.com/albums/y23...ringloom15.jpg
Re soldered. So that the same gauge wiring does all the feed, so from plug run in to the fuse box (own fuse in spare hole) then to the pump.
http://i6.photobucket.com/albums/y23...ringloom18.jpg
Way way better.
http://i6.photobucket.com/albums/y23...ringloom19.jpg
So its been re routed to be much tidier,
Under side.
http://i6.photobucket.com/albums/y23...ringloom21.jpg
As in pic above the ground was re made too, was in the chassis leg. But what better ground is there than the battery, as its almost right above the battery it was run to it.
http://i6.photobucket.com/albums/y23...ringloom22.jpg
Much better and safer.
Now while the side trims is out, i've cleaned it fully with a good scrub and these looked very tidied..
http://i6.photobucket.com/albums/y23...iringloom7.jpg
http://i6.photobucket.com/albums/y23...iringloom6.jpg
To all nice and stained black... Mucho better.
http://i6.photobucket.com/albums/y23...iringloom8.jpg
hi benn think ill be mithering you about the job u did with the fuel pump wire,.. nice work as per..
hmm ive had this before where people in the south arent familar with mithering..
pestering then.. questioning lol.
Ah ok dude, ask away when ever.
Cheers J.
Cheers dude. Finding out tonight when it can be painted.
