Brucer, its a screw driver...:confused: lol Normal would be sitting on the black part of the grille.
Been thinking for a while that i fancy for vents putting in to the bonnet, to help get the heat out and i like them.. Now they'll be pressed down ward so they are smooth from the top (a must) and will match the wing vents..
http://i345.photobucket.com/albums/p...010NOscoop.jpg
Liking this alot.. Will only have a row each side, not the ones in the middle..
http://i345.photobucket.com/albums/p...010louves2.jpg
What do ya think...
Big thanks to Southie for the ps.
i,d go for flushed saphire 4x4 cossie vents or,courtenay had a nice minuture set if u can find them,oh in get them cav rims removed there well boring :eek: looked better with speedlines
Vents would look cool, and they serve a purpose.
Hmmm, not too sure. Might look to "venty" if that makes sense? EDIT: just seen the other replies...what vents did (cant remember the reg, the dark green minter) have on it? They would look cool.
Strut brace will look hot when polished up. I had a similar issue with the fitting of mine. Not enough thread to put nuts on. I used longer bolts, intended to mig them to the strut tops, but i guess these are stainless??!! In the end had to do a minor bit of engineering to get them on!!
Brace looks well in the bay.
Might be worth removing the pic with your address in...........
K85 VHD.Quote:
Originally Posted by Pete_58
Preety sure there custom/old school vents that are uber hard to find, plus there sat on top of the bonnet, IIRC anyway.
Thats the one. I thought the were 4x4 cossie vents?
You might be right, cant remember now lolQuote:
I dont like them vents, to rounded shape, when every thing else is square and boxy, Speedline's are frigging sh*te. I hated them when i had them on it. Way to common.Quote:
Originally Posted by mrT
:)Quote:
Originally Posted by AW06
Yeah Aw's just said about swapping the studs on the top mounts.Quote:
You think to much ventage? Even with only 5 in a line each side?
Cheers didn't know you could read it..Quote:
Originally Posted by Adam
