just read all of this from the begining and what a top read it was!:thumb: i know what you mean with the bilstein dampers i had some on my corsa(b12 kit) and when i got them out of the packaging i was like :eek:
Wasted a whole morning trying to sort out wiring ! Im useing a cav gsi engine loom and its got 3 big plug on the inside of the car ! What are they for ? I know one id a fuel relay tho ! Where are the wires i need to connect to on the nova loom? Starting to get problems cause i didnt take the nova to bits !
Not been looking forward to having to wrap the exhaust manifold. I got the wrap from ebay and had some spare time today to decided to wrap it ! I was given some advise from jonlem to wet the wrap first but for some reason i thought this wrap might not make me itch !!! Anyway i took me the best part of an hour and a half to wrap it adn heres the result:
http://img2.putfile.com/thumb/5/13915475821.jpg
http://img2.putfile.com/thumb/5/13915475816.jpg
I also got some heat proof paint with the wrap. Should i paint the whole lot of leave it as it is !?! Heres the test patch on the end of the manifold.
http://img2.putfile.com/thumb/5/13915475872.jpg
should i ?
Got a few more parts panted red. Drums and both anti-roll bars.
http://img2.putfile.com/thumb/5/14012095011.jpg
The car seem to sit to high on the bilstein suspension springs !
http://img2.putfile.com/thumb/5/14508121520.jpg
Got some more bits and bobs done to the nova. PVS is out of the window but im now going to aim for trax, makes sence as it will be a track car and not a drag car ! Got the wrapped exhaust all painted in heat proof silver paint, think it looks kinda cool.
http://img2.putfile.com/thumb/5/14508121499.jpg
http://img2.putfile.com/thumb/5/14508121439.jpg
The down pipes do seem to sit low so i need to try and angle them up without fouling the sump.
Also put my gsi anti-roll bar in the rear beam. Went in a sight better than it come out !
http://img2.putfile.com/thumb/5/14508121451.jpg
I have also sorted out my boot install http://www.migweb.co.uk/forums/image...s/rolleyes.gif well, the tank and the battery box. Im going to use some heavyduty amp cable to run the power to the engine bay, will it be ok !?!
Boot install:
http://img2.putfile.com/thumb/5/1450812159.jpg
Cant forget the little touches http://www.migweb.co.uk/forums/images/smilies/wink.gif
Omp sticker on cage:
http://img2.putfile.com/thumb/5/14508121562.jpg
Also got my FPR, sadly i wont have the money to tune the engine as i would like so its just getting some simple mods. Hope to hit 175 bhp, which should be plenty.
http://img2.putfile.com/thumb/5/14508121527.jpg
http://img2.putfile.com/thumb/5/14508121565.jpg
a proper boot install minty mint!!
Think its about time for a update on the work ! Been a while since i done any. I've just decided to get the body ready for paint and leave the engine and bits until it all painted. The original plan was to get it running then paint it but, i changed it !
Had a couple of hours this afternoon so just finished of the filler work on the arches. The arches will be primed with high build primer then flatted and then the whole outer shell will get another coat of high build primer, then flatted for a smoother than smooth finish http://www.migweb.co.uk/forums/images/smilies/smile.gif
http://img2.putfile.com/thumb/6/15813312990.jpg
http://img2.putfile.com/thumb/6/15813312857.jpg
Will get some more pics when it all primed. http://www.migweb.co.uk/forums/images/smilies/nod.gif
Good progress mate, starting to come together well now.
Keep up the good work
Ian
what is the breather mod 4
