Car looks to be held together with gaffa tape
Ratios are in the box and the engine and box are back in the car.
Top front mount is screwed, we've worked out that the bush is acting in the wrong plane.
https://youtube.com/shorts/tbL7IsKh80U?feature=share
Need to spin the bush through 90 degrees, time to get the funk out.....
https://uploads.tapatalk-cdn.com/202...6ca0e0a24d.jpg
https://uploads.tapatalk-cdn.com/202...9aae8c6026.jpg
https://uploads.tapatalk-cdn.com/202...ce88ba337a.jpg
https://uploads.tapatalk-cdn.com/202...1235157184.jpg
https://uploads.tapatalk-cdn.com/202...3ab70dc891.jpg
https://uploads.tapatalk-cdn.com/202...a389fd4175.jpg
https://uploads.tapatalk-cdn.com/202...106bb22a3e.jpg
Freely admit my TIGing is not the best, I probably should have MIG'd it or tacked it and got Ben to do a proper job, as it is as soon as Ben has time this will be re-made by him properly.
But we've got the bush spun through 90 so it's acting in the same plane as the gearbox mount, also lifted the engine 2-3mm which we're hoping will move the alternator away from the chassis leg.
More this week, 4th engine mount, changing master cylinders, prep for Snet in the middle of June.
https://uploads.tapatalk-cdn.com/202...b86378bc3e.jpg
Got scared when I got to the workshop this morning and looked at it, reverted back to type and fired the MIG up!! Happier with that.
Nice welding,!
TIG was horrendous, MIG slightly better!!!
But we're back in action
https://youtube.com/shorts/s6NcJa8yzoQ?feature=share
Until I found this
https://uploads.tapatalk-cdn.com/202...7a6512fe5b.jpg
My hulk muscles went OTT!!
Gotta get a whole new hose made up as they're crimped fittings!!!
But she doesn't look too bad in her old age
https://uploads.tapatalk-cdn.com/202...903bd02774.jpg
Think Automotive hooked me up with a new hose while I waited
https://uploads.tapatalk-cdn.com/202...740d0a6d82.jpg
Also they gave me the torque figures for each size of fitting so I won't make that mistake again.
All fitted and back up and running.
Booked onto Snetterton 25th of this month for a little shake down and test. Hopefully good weather, forecast looks ok.
https://uploads.tapatalk-cdn.com/202...66ffd33981.jpg
https://uploads.tapatalk-cdn.com/202...83ea38c425.jpg
No idea if this will make a difference but it looks badass!!!
Board is temporary, I'll add some proper buffalo board when I decide if it makes a difference or not
25th at Snet you say.. half tempted to take mine to work and pop in.
Good work though. I need to get my project post updated.
