Mine came with an adjustable top hole as standard, At the nurburgring this allowed the knuckle to move. So when I got home I had a metal plate welded over the hole and it drilled out to the correct position.Quote:
Originally Posted by Martin
If you enlarge the hole olly, get it to your desired position and then weld a washer on to stop it moving (like you said you would) :thumb:
