Good work :)
Good work :)
Cheers dude, i wanna do a photo shoot with Pete soon as he's beautied up the front end.Quote:
Originally Posted by Graeme Dixon
I did have some, but didn't like the way you did them up. If i can i'll sort out a fixing screw for the disk.Quote:
Cheers dude.Quote:
Originally Posted by Adam
well done Benn, you always seem to find the answers !!!!!!!!!!!!
what brake disc did you end up using and what size?
was they correct centre bore?
Its a Vag fitment disk. The center bore was 5mm out. The hubs have a thicker bit on the inner part. It had to be turned down.
Disk is a 280mm like the ones that come in the kit.
Nice job on the brakes. I love your car!
:) Thank you Sir.
Need some longer bolts.. Ggrrr i cant find any.
Awesome mate. Keep raising that bar!
Thank you :) I try.
Small up date.
Big big thanks to my dad and Dan.
My Dad got me the longer bolts i needed for the brakes, they came today. So had a bit of a dash on to get everything on and working so i can go on the rollers tomoz..
Gonna get some better spacers made up as at the mo i have two thick washers in there. But got everything up and sorted.
Then Dan popped over and gave me a hand bleeding the brakes up.. Not that easy getting to the bleed nipples on these Wilwood calipar's tho. After a bit of messing about got that sorted and took it for a test drive.
They work much much better than the 284mm. I need to remove the travel out of the pedal a bit tho...
i have the same problem with the pedal think im going to try upgrading the mastercylinder
