So... to update on where things have progressed since August.
Part 1 of 3
There was a lot of standing around in dissatisfaction with some of the previous work I had done to the frame and I decided if I didn’t correct/change/improve it now I knew I would regret it. However, with such long term projects there has to be compromise as things are always evolving and I could just end up going around in circles! There was even a moment in October where I was considering completely starting again! [emoji85]
So I decided it would be sensible to work back to front, which started with the rear panelling. It was sloppy, rough and the recess inconsistent.
https://uploads.tapatalk-cdn.com/202...24cb6fbb13.jpg
So starting with pass side it was all chopped out and with some jiggery & spacers I piloted building a frame out of 3x10mm plate...
https://uploads.tapatalk-cdn.com/202...a0e7c6c852.jpg
https://uploads.tapatalk-cdn.com/202...d6abbdb848.jpg
Then some 1mm sheet and you get the idea...
https://uploads.tapatalk-cdn.com/202...ac5d78e435.jpg
https://uploads.tapatalk-cdn.com/202...5a056b5e0c.jpg
