at least it's better than some of my previous updates, which have simply been to announce that I've done nothing lol
I can't work out the relative positions of your sump/manifold/gearbox though. has the sump been modified, or am I up too late?
Thanks goodness the engine has today been fired up for the first time since the paintwork and other rebuilding.
It needed a bit of detective work by someone cleverer than me, as I couldn't get it to spark........turns out one of the pins in the connector for the crank sensor was not pushed fully home, so I only have myself to blame.
There's now an arm-long list of jobs to be ticked off before the first race on 21st April.
Good to hear its running again
As a precaution I'd check all the connectors if you have had a pin drop out, you certainly wouldn't want it to drop a injector on full boost
The Nova took a test run on Saturday afternoon, with no doors, no wings, no bonnet, no tailgate and no windscreen. Quite breezy.
The clutch has been giving us major headaches, and still isn't quite right, it looks like long term the master and/or slave cylinder will need to be changed. But hopefully it will be OK for the racing this weekend.
A few photos of it sat in my friends' workshop;
http://i285.photobucket.com/albums/l...ort/001-48.jpg
http://i285.photobucket.com/albums/l...ort/002-82.jpg
http://i285.photobucket.com/albums/l...ort/003-85.jpg
I would never have got it to this stage without his help, that's for sure. We've now spent 4 days pretty much non-stop on it.
Suspension geometry is now all set-up, the doors have now been primed, and will be top coated tomorrow. So I now have to bolt on all the bodywork (not a big job on this!).
I'll fit this rather natty new 'catch tank' tomorrow;
http://i285.photobucket.com/albums/l...ort/004-72.jpg
And then I need to make some panels to fill the rather gaping hole in the boot;
http://i285.photobucket.com/albums/l...ort/006-65.jpg
http://i285.photobucket.com/albums/l...ort/005-61.jpg
Other jobs to be ticked off are;
Getting the tyres filled with nitrogen (now available at our local tyre depot)
A bit of tidying for the wiring
Sealing up various holes in the bulkhead/floorpan
Bleeding the cooling system
Fitting the battery properly (I had to send the race battery back due to charging problems, and it's coming back to me tomorrow)
Machine polishing the paintwork
And a bunch of other little jobs, so more late nights.....
colin, if there is no rule on what you need to make it out of, could i suggest using that corrugated plastic stuff they use on cheap coldframes & sell at b&q, correx it think its called... it weighs about a 1/4 of feck all...
Mental Nova!
I'm not familiar with that material, I was going to make it out of carbon fibre, but as I'm in a rush and don't really have time to make a lot of templates, your cheap and cheerful suggestion might be the one for me (no rules on what the infill panels are made of, so far as I am aware).
Crack on, looking the part now Colin!
Giving me some real good ideas/inspiration of something Im planning on building at some point.
