No mate, the cement stuff isn't rtv. It doesn't smell of vinegar (lol) it's the stuff used to glue sumps on, when there is no gasket. ie steel pan to alloy block etc.Quote:
It looks a tad thicker. I asked as those two fans look a decent size. I could go for 1 large fan but need to check out how much room I'd have left. The IC will probably be mounted slightly higher than normal due the the front being a snowplough so that will have some bearing on what size fan, inside or out and how large.Quote:
Oh that stuff, Fiat use it. If it comes it yeah i'll have a tube.Quote:
Originally Posted by John H
I'd rather have a bit bigger fans, but they work very well and keep the car happy. Cut the cross member and you can mount it as low as you want. Wish i had gone a bit lower, but its right in the mouth so gets good air flow.Quote:
Originally Posted by Nova_Tek
pm address. ;)
not really, an odd drop from time to time, but ive never noticed an affect on the oil level, it leaks feck all really. and mine spends most of its time running in the shed and no puddlelolQuote:
on another note, any other nova id be iffy on the bra, but on this i thinks it looks good:thumb:
It dont look pretty, but it's worked, i had small leaks all about the sump even after i replaced mine and put the short bolts in, and then i got small leaks from the cooler pipes and a bit at the back of the filter too, so i just got pissed off and smeared the sealant ALL over and joint! lolQuote:
Yeah see mines been in the garage since Sunday, and there's a puddle about 2inch wide under it. But the oil level don't go down ....Quote:
Originally Posted by alan b
Just done it. Cleaned it with brake cleaner then smeared it on over the joins all round and used my finger to even it out. Looks poo, but leaking looks worse.Quote:
Mine would drop a penny sized amount over a weekend, nothing for me to care or worry about. I could probably make it worse changing the gasket!
what size fans are they on you rad ben?
Oh right about the same as mine then.. Is just messy. Underside looks worse.. but keeps it protected..lolQuote:
As said about 7 times, they are twin 7inch.Quote:
Originally Posted by let_nova
