Originally Posted by 16v-kev
No offence taken mate !
the trouble is when fitting the metal rings it transfers more pressure to the main diff in the txb if you look at turbodazzs cav turbo which had mikes rings fitted this also gave up the ghost so there is problems both ways i prefere to use the clutch plate rings as it does give a little and also turbodave has run a vts box for nearly 75k and has done trackdays 1/4 miles and daft things like that so there are pros and cons with both set ups at the end of the day the vauxhall txb is really a choclate box and will give up no matter what you do to them ! lol
but keep up the good work i look forward to the next installment
