2018, few upgrades planned prior to MOT in April.
New mongoose exhaust
Fit new bonnet release cable
Oil and filter change
Fit toe shims on rear as after lowering it runs toe out which makes it nervous in fast corners.
Hopefully the shims will take it back to toe in. ( will get alignment check at mot.
New gearbox, either helical fixit full gearset or Pete Dougherty
box with straight cut 2nd and 3rd (the 2 weak gears) as this also leaves 5th gear nice and quiet for the motorway.
When new box in turn boost up to 30-32psi peak (currently peaks 26psi
