Looks awesome! What size of wheels are they on the front mate?
13x10j
Update
Boot floor changed to take new 2l fuel tank
And a couple more jobs done
http://i23.photobucket.com/albums/b3...psevw7qvr6.jpg
http://i23.photobucket.com/albums/b3...psihpzry9g.jpg
http://i23.photobucket.com/albums/b3...pskvtudlgu.jpg
http://i23.photobucket.com/albums/b3...ps5pw09dsa.jpg
http://i23.photobucket.com/albums/b3...pskcocgqij.jpg
http://i23.photobucket.com/albums/b3...pslh8m7ban.jpg
http://i23.photobucket.com/albums/b3...ps1fdever0.jpg
Loosing the dash . Unwanted weight
http://i23.photobucket.com/albums/b3...pserpbqvzl.jpg
http://i23.photobucket.com/albums/b3...psv9aadjlu.jpg
http://i23.photobucket.com/albums/b3...psmyuwby45.png
As said the dash is going
I have a set of solid engine mounts to fit
New slicks and need to build a rose jointed gear linkage this weekend
. Pics to follow
Loving this! Saloon arches work well for clearance.
Cheers bud .yes mate the front end went much lower with the loon arches on
And the gap is nice and even unlike with wide wheels and 3dr hatch arches .
Productive weekend on the car manage to get new slicks and gear linkage sorted , rear engine mount fitted and new dash fitted.
http://i23.photobucket.com/albums/b3...pszzea6jyf.jpg
http://i23.photobucket.com/albums/b3...psvqlodyjs.jpg
http://i23.photobucket.com/albums/b3...psc6umvp8m.jpg
http://i23.photobucket.com/albums/b3...psdokt3dbc.jpg
Been a while .
Bit of an update
Stripped the heavy loom and fuse box out made a light weight loom around 8 wired.
Full cross cage with harness bar
New nascar style harness.
Bonnet catches .
Rear defuser.
Converted triple core alloy civic rad to work with xe
http://i23.photobucket.com/albums/b3...psxmqa2mil.jpg
http://i23.photobucket.com/albums/b3...psl6vuvnjg.jpg
http://i23.photobucket.com/albums/b3...psa0mb6wqb.jpg
http://i23.photobucket.com/albums/b3...pshz4ibylq.jpg
Looks well that mate
Decent, quite a change from the start!! Looks good.
Looks hard as fook..
Cheers lads
Just bought this to take place of the xe for next yea
C20let
Wossner pistons and h beam rods
Xe inlet cam
Stainless tubular manifold and t3/t4 hybrid
Vxr injectors
http://i23.photobucket.com/albums/b3...pstlr5bdnl.jpg
http://i23.photobucket.com/albums/b3...pshtwrkzif.jpg
Motor had fresh rebuild around 3 years ago but has not been used since .
So is going for another rebuild and head work over winter.
Plans are
Omex 600
Custom inlet plenum
Aem methanol approved fuel pump and lines
Running methanol for cooling aswell as perfomance so i can chuck a few more hp of gas at it.
Xev coil pack
Should make a bit more power than the xe
http://i23.photobucket.com/albums/b3...pskwmduz0x.jpg
Couple of pics from last weekend
http://i23.photobucket.com/albums/b3...pslau3bnnk.png
http://i23.photobucket.com/albums/b3...psiwbaohpe.png
Like the flip in aero mirrors...
Cool arnt they lol .
Pissed me off all weekend its had the glue treatment now no longer folds in at Mach 3 lol
Just looked back. Love that you dont use rear shocks. Is it not mega bouncy?
The Let with me a great uprate. You'll get your times down nicely.
No the rear works very well . I thought the same when i first fit them and was a bit sketchy first few runs but once i knew it didnt bounce about was fine . Car is 0.1 from a 12 sec and was hoping to get the xe into the 12s in october before i pull it out. Im sure sub 12s require a min of 25 mm travel though so will probs have to fit coilovers next year . Hopefully new spoiler will bring the ET up a couple of mph .
The let will hopefully make good power and handel alot more gas.
Anyone know if the omex ecu works as a nitrous controller aswell or does it just work with nitrous and still require a seprate controller .
Cheers
Lots of good plans, will be very interesting to read up on.
I think from what i've seen you'd need a big power xe to get in to mid 12 wouldnt you?
The car is only 0.1 from a 12 sec pass im sure the drag spoiler and another 25hp of gas will get it a 12 before i remove it .
The xe will also be forsale once removed so will be good to get a 12 secs pass in the bag just to show what its capable of.
i think your rear wheel is off the ground
Removed the old standard concrete spoiler and began making the new alloy one .
Not fitted yet but up to now.
http://i23.photobucket.com/albums/b3...ps0ywoejkv.jpg
http://i23.photobucket.com/albums/b3...psoibshwke.jpg
http://i23.photobucket.com/albums/b3...pssjtm54h8.jpg
http://i23.photobucket.com/albums/b3...ps94pvj1l4.jpg
Going to wrap it and will need to make a couple of little supports of the rear window
That looks great, exactly the style I'm after actually [emoji56]but a lot deeper
Like it
Sent from my Nexus 4 using Tapatalk
Looks really good, when you making mine? [emoji6]
Last ever run for the xe in this car.
Make way for the let
https://youtu.be/4v2SyegU0Z0
https://youtu.be/YBW7zbeHLRg
http://i23.photobucket.com/albums/b3...psxjmvxprq.jpg
Began stripping the car ready to start the fabrication work on space frame .
http://i23.photobucket.com/albums/b3...psekxbloer.jpg
http://i23.photobucket.com/albums/b3...psvqzalyrd.jpg
And these should save a bit more weight
Cheers heds:thumb:
http://i23.photobucket.com/albums/b3...pst4yidijy.jpg
Yes! Chop chop, I like it!
And no problem dude [emoji1360]
Few more bits added today rear brace back to cage and all the front to fully weld but getting there.
Nice work mate, you ain't hanging about [emoji1360]
Had alan round all day aswell massive help
http://i23.photobucket.com/albums/b3...psejgrddod.jpg
Nearly sorted boxed all the bottom arm mounts in to try and stiffen front end up a bit . Battery tray to remove and mod to take pedal box
You left enough room to get mounts on legs?
Here's one for inspiration from a lad I knew
http://uploads.tapatalk-cdn.com/2016...a41e5ef1e6.jpg
Yea mate legs are still in same place 812 mm apart at front mount area so just need to make new mounts to suit
