Just running the nova arb or going to do a secondary one?
Oooh lots of nice piccies to look at. [emoji7]
Verstuurd vanaf mijn SM-A505FN met Tapatalk
Great stuff!
Awesome work there man, if you can get the wheel trims on definitely do it lol
Beast of a Nova, pretty much as i would have wanted back in the day [emoji16]
The hidden gauge in the vent looks spot on too
Sent from my SM-G950F using Tapatalk
Building a custom Rose jointed shortened gear linkage using all stainless fasteners, this involved quite a bit of cutting, drilling and tapping threads Into it, but was well worth it in the end, theres a big difference between the standard linkage, added holes for small weight saving [emoji23]https://uploads.tapatalk-cdn.com/202...6be4492f91.jpghttps://uploads.tapatalk-cdn.com/202...7c85e47dcf.jpghttps://uploads.tapatalk-cdn.com/202...41dbb14778.jpghttps://uploads.tapatalk-cdn.com/202...371da33522.jpg
Sent from my VOG-L29 using Tapatalk
Good mod. It's hassle but feels loads better. Not something I'd personally consider weakening with holes although I guess this ones way stronger than standard to begin with
I searched around a bit to find new screws and fittings for interior pieces, to keep it as factory correct as I can.https://uploads.tapatalk-cdn.com/202...0f9cab7474.jpghttps://uploads.tapatalk-cdn.com/202...65114787b2.jpghttps://uploads.tapatalk-cdn.com/202...79c48bf534.jpghttps://uploads.tapatalk-cdn.com/202...001b62bdfb.jpg
Got the original green tint glass with the original reg etched Into them.https://uploads.tapatalk-cdn.com/202...feb52ce2df.jpg
GTE rear parcel shelf and supports, that were in need of some restoration, I stripped the supports down and re painted the metal parts, then sourced some higher quality fabric that is the same colour as the originals, and retrimmed them and the parcel shelf, I think I will retrim the whole boot carpet too, to make it super clean.https://uploads.tapatalk-cdn.com/202...afd563a406.jpghttps://uploads.tapatalk-cdn.com/202...a41716bfb2.jpghttps://uploads.tapatalk-cdn.com/202...1f5308be61.jpghttps://uploads.tapatalk-cdn.com/202...9bbdab6f81.jpghttps://uploads.tapatalk-cdn.com/202...a8fd85f53a.jpghttps://uploads.tapatalk-cdn.com/202...071cde2b1e.jpg
Solid doors, the green door is actually the original factory GTE door, with original etched glass, both doors stripped back to bare metal and epoxy primed.https://uploads.tapatalk-cdn.com/202...ccaed2e341.jpghttps://uploads.tapatalk-cdn.com/202...daf436d52e.jpghttps://uploads.tapatalk-cdn.com/202...bca29adfa6.jpghttps://uploads.tapatalk-cdn.com/202...ffff71ffe3.jpg
Oooh nice touches! Following this. [emoji1362]
Parcel shelf looks really good, you should be happy with that.
Looks well where did you get the material from if you dont mind me asking?
On eBay, here. The light grey one I think.
https://www.ebay.co.uk/itm/Thick-Car....m46890.l49292
Cheers
Wide arch front wings, to fit the drag racing wheels under.https://uploads.tapatalk-cdn.com/202...eece5e7841.jpghttps://uploads.tapatalk-cdn.com/202...60c21cb965.jpg
Are them wings from the lad at darlo?
Took the nova out for a test run over the weekend, I think it grips much better with the new wheels and tyres, here's a little video.
https://youtu.be/z1qRyZeXzMI
Looking menacing mate! Did you get the courtenay cage off Chris Murphy?
Loving the updates on this lew can't wait to see it again. Also glad you put it back standard ish
Just watched this on YouTube Adam smith channel sounds incredible!
Heres the video, for those who haven't seen it
https://youtu.be/_FSXHg1W4RE
Small update, new spal slimline fan fitted to the radiator, and I'm making a start on fitting a chargecooler system, so no more big front mount intercooler, here's a photo from USC Santa pod 2021.https://uploads.tapatalk-cdn.com/202...68d3a7cee0.jpghttps://uploads.tapatalk-cdn.com/202...dcacf153e6.jpghttps://uploads.tapatalk-cdn.com/202...5f0bca5b4e.jpg
I like the fan.
How's your nova Ben owt different?
More work fitting chargecooler system, 3" boost pipes, Mounting radiator and water pump.https://uploads.tapatalk-cdn.com/202...3373f1fad2.jpg
Looking great pal nice work. Got a xe rocker cover with the metal plug cover in vht matt black if interested no use to me now.
That charge cooler isn't going to be hugely efficient with such a small pre-rad. did it and get a bigger one... Ive seen Fiat Cinqecento rads used.
Yea that charge cooler rad would be better a lot thinner and a lot bigger to get more air across a thinner larger area, nice work fitting the chargecooler in there though, looks a tight fit!
Selling a set of 875 injectors if yourr intrested. 100 quid
