I knocked this up to test, it is a scary thought that if the timing is spot on ...........
http://i227.photobucket.com/albums/d...airboxbinj.jpg
Looks ace Ste! I've been following you build thread since day one, and it's right up my street.
I don't know why you lot are well against the idea. It would take a miracle for it to explode in some sort of Bruce Willis based film. No different to multiple carbs. If you think about it. Although being contained, the entry point of fuel in a carb is quite a distance from the inlet ports.
I wouldn't be against an enclosed system, but one like in the original vid where the fuel is basically being sucked across an air gap (as in, not enclosed) into the engine... hmm. Its still possible to flibble petrol everywhere, afaik in some applications its even designed for some of the fuel to drop out of suspension and not go in the engine
A car of many tricks.
Me and my friend have a name for the JDM induction kits, that are styled very much like that. Would anyone like to hazard a guess?
cant gess so tell useQuote:
Originally Posted by db_1.2
Widow makers?Quote:
External injection = external combustion lol
and how exactly would the wording on the insurance modifaction list go?
" well it has injectors that squirt petrol at the engine, it's not a fire hazard as the engine sucks the petrol out of the air so it's all good"
fook any benifit that may bring, i wouldnt run the risk of looking like Niki lauda for the sake of a few bhp,
You're obviously not dedicated enough :pQuote:
Originally Posted by bazil
I love how jumpy people are about it, you do realise a 1.2spi is set up in a similar fashion, and carbs work purely by sucking fuel into the engine, they don't even squirt it in properly lol
Real heroes use these...........
http://t1.gstatic.com/images?q=tbn:A...WsFf8NXRjNB1US
Squirts in a /\ fashion straight onto/past the butterfly. I found that out when I took mine apart while it was running.Quote:
Originally Posted by MK999
Indeed, must be a fire hazard! Direct injection only pleaselol
A 1.2 spi will pass an mot and even trackday scrutineering with it's setup,
I very much doubt that external injection would pass either,
You better get onto the F1 teams sharpish then because the first race of the season is coming up! lolQuote:
taken from FIA regulations,Quote:
5.8.1 The pressure of the fuel supplied to the injectors may not exceed 100 bar. Sensors must be fitted which directly measure the pressure of the fuel supplied to the injectors, these signals must be supplied to the FIA data logger.
5.8.2 Only one fuel injector per cylinder is permitted which must inject directly into the side or the top of the inlet port.
Lol I like....Quote:
Originally Posted by wwmnw
I don't know where it came from, but, we call them whale cocks!
I've seen 5th injectors on FIA approved cars....Quote:
Edit- what the hell is external injection anyway?!
and the ones from the F1 testing vid fire directly into the top of the inlet port, so?Quote:
Generally F1 cars have 8, db lol
Good idea for water injection I think...
but in this case MAD! :)
Lol I mean the term external injection. I googles that, and nothing car related came up. I always thought the technical term was stand off injectors.Quote:
