nice mate thats how all sr's should be the 1300 on webbers!! nice work mate!
mines a 1400 mate, still got my entire 1300 engine tho, just going to have it worked and the head acid bathed to get all the oil-ways and all the ports cleaned out, i might even look into a new shell for it and do a sport rep maybe...
cheers wudgey! mines a 1400 tho mate, still got my entire 1300 engine tho, just going to have it worked and the head acid bathed to get all the oil-ways and all the ports cleaned out, i might even look into a new shell for it and do a sport rep maybe...
thought id post a couple more pics... is there a limit to how many photos you can post!?!!
http://i797.photobucket.com/albums/y...an/1112092.jpg
its looking awesome with the DCOEs, i need to get my hands on some filters...
http://i797.photobucket.com/albums/y...n/Image037.jpg
one half of where my back seat used to be...
http://i797.photobucket.com/albums/y...Image038-1.jpg
and the other half... then i decided it all weighed too much, so i reduced the stereo a bit...!
http://i797.photobucket.com/albums/y...n/Image463.jpg
and this is what ive got now, just needs upholstering, engine has taken precedence!
http://i797.photobucket.com/albums/y...reconsole1.jpg
something i knocked up, so simple..!
http://i797.photobucket.com/albums/y...tendnewest.jpg
over-all frontal view...!
i cant wait for this gearbox... nightmare...!
Im liking that engine mate:thumb:
and that sound system looks good:cool:
Originally Posted by Joe Richardson
Cheers Joe, cant wait to get it fired up, Which install?!?! the full on one or the half stripped out look one?!!
The full on one mate,but the half looks good aswell:)Quote:
Originally Posted by Mk1'SR'Dan
that was a good build, but really bulky, the main bit was 20mm MDF, the shelf was reinforced with 18mm MDF, even the shelf cheek original speaker holes were blocked up with MDF, was all a bit changing rooms for my liking so i chipped the majority of it off, especially as the fabric ive used to upholster it is sensitive to sunlight, so ive got to redo all 4 'door cards', and the new install, so much to do and the interior is well and truly on the back burner atm...! cheers for the feedback :)
BUMP! :d
Dont bump.
apologies! didnt realise it irritated people!
hello folks, its been a while, a depressing while... after getting the engine in and realising the gearbox was wrong, ive since got my hands on an F13 bell housing which im going to fit my F10 transmission into, but, now i cant get a (290mm approx) flywheel for it because the bloke i bought the engine off has flogged it to someone else... annoyance... so while im waiting for one to turn up (if anyone on here could help it would be awesome) im mirror polishing the F13 bell housing so it looks alot better when its bolted to the new engine, thats going well, id post some pics but my proper phome is sh*gged and the temporary one is w*nk... also got my interview for the foundation degree in motorsport engineering... result..!!
hello peeps, i finally got the old shed running, got a flywheel on saturday, had that and hew clutch on and had the gearbox rebuilt and fitted by that afternoon, got some gearbox oil and petrol earlier and got it going, now for the teething troubles... one of my carbs is a little bit sticky and doesnt close off properly, so it runs really fast unless you physically pull the throttle closed, hopefully with a bit of adjustment of the throttle linkage should sort that out, another thing was (hopefully cured now) is that the fuel seems to be pre-detonating in the inlet manifold, hopefully i havnt damaged the mis-abs too much, bit of a tweek up hopefully cured that, another thing is the return fuel pipe, im not sure what to do about it, because im only running the mechanical pump until ive strengthened the bottom end up im wondering if i need to have a return until i get some ARP bolts in the rods and ive got a facet pump? its backfiring so im guessing its just about running rich enough, although i think it'd hunt a bit higher revs, if anyone could help with my above issues i would be eternally grateful!!
its done... with the possible exception of some more new jets...
twit twoo
eh?!!!:tard:
He wolf whistled lolQuote:
Looking good btw, liking the rocker cover. :cool:
oh i see!! cheers southie, the block is that colour too, i love it but shes being a right bitch atm, got wiring troubles.... :(
engine looks sweet mate....i like it :)
cheers luke!
