i will be useing a sheet of metal from the side of a van and then sealing it and then riveting it down nice and cheap
Just an idea, the sunroof in my mk2 is a 'Solarport' or something. If its the same size you can have it and the fixings. Then just replace the glass with polycarb ;)
Thanks for the offer Ash, might take you up on that.
Not keen on replacing the roof skin. Ideally I didn't want a bodyshop to do too much to the car.
Will keep investigating.
IIRC Dave Marshall had a nice solution to it. He cut the lip off the nova roof skin which is left when the sunroof was removed and then he used a window rubber and had a piece of clear perspex to fill the hole. Looked a neat solution.
I was just chatting to MC about a similar suggestion Rick. My only concern with that is the polycarb suddenly flying out, lol.
A roof vent is starting to enter my thoughts too...
http://www.migweb.co.uk/forums/car-t...stage-2-a.html
There is the post. To combat it popping out i would fit 4 brackets (one at each corner) and countersink 4 screw holes into the perspex that would hold it tight inplace and stop it popping out.
i don't think it would pop out as it was a nightmare to fit and very secure
Cheers Rick.
