Also all you people with carb novas you can do the ol switch the ignition key on an off for no money. Now thats class.
pretty much what it suggest really, its keeps the turbo spooling and boost up in the basic terms.Quote:
Originally Posted by eastbourne racer
its where fuel is still injected, without being ignited, after the throttle plate has closedQuote:
the fuel then ignites in the manifold or turbo housing, and the gas produce keeps the turbo spinning, thus creating boost, whilst off throttle
therefore eliminating lag!
I dont get lag with my electric supercharger, it always spins at a steady 300 million rpm and keeps me in negative boost.
^^^^ pmsl lol but yeah stu has it spack on thats what the poping noise is the unignited fuel igniting in the exhaust
alrite cheers for that, whats that carb thing phil?
drive down the road, turn the ignition off let it run through in gear for a good few seconds. Then turn it back, BANG you get some well trick flames out the back and lots of street cred.
Were you smoking crack whilst you made that statement lolQuote:
Originally Posted by dannyb
Who the **** is this Lee Mitchum fella as he seems to be the god behind novas :roll:
Plenty of people have used it and many more certainly have an ecu capable of running it, as I originally said, to use it properly you DO need a iconel shafted turbo or its going to end in tears at some point.
Phil, tbh its best not to try an be too different, the way anti lag works is quite simple and it doesn't require much more than a modded iscv and throttle body and a suitable ecu to get some proper gains.
Are you on a GT30 ?
Your using megasquirt yeh ? does that have a anti lag facility, if so make use of it mate although tbh as you use it nitrous is the best form of anti lag and it won't **** everything in the process :p
Looking forward to seeing the car out doing the times it should be :thumb:
Oh dear god, I can't believe you admitted to that, how old are you lolQuote:
Originally Posted by Philsutton
LMFAO, everyone has done it you cant deny it
