brick through the window then lol
Brick through the window seems the logical next peice of advice!
doh!
i just binned a few windows i diddnt need aswell lol o well im sure ill work a way in when i get there and have a look. thanx fellas
can you not remove the rubber from one of th ewindows and climb in that way ?? just keep your logbook in your pocket in case neighbour hood watch get wind of what your doing
thats one of the reasons why i didnt do my boot due to the fact incase i could never get in the bloody thing
enter by house brick now :D or call out the RAC/AA and say your locked out :thumb: they WILL be able to open it ;)
put a wire down the window rubber and try to pull the latch.
cut the rubber of the small front window ( it may pop out but i doubt it)
try and yank the bonnet release (under the bonnet)
I have known all of thease tricks to work, i wouldent go breaking windows there really is no need
NOOOO its piss easy to brakin to a nova all you need is a 3mm rod with it bend over 10mm at one end at 90 degrees then pull the seal off the top of the door push the rod down and you can work the linkage will take awile to find the right bit tho done it afew times now lets hope hes not just gone n smshed his window
ps i think uve gotta push part of the linkage down which wil raise the door pin
edit thats if u have any handles but i might be able to do the same with the hanlde with the rod
phil
bonnet relase is a gud 1 bigbened u might be best brakein ur grill and then doin the spring with a screwdriver rather than smashing a window better putin a new grill on than fittin a new window
